As I build my trailer I ...
record or write notes on every move.
0
No votes
using baught plans follow each step changing nothing
0
No votes
Keep a 3 ring notbook filled with scetches, notes, & pic's
3
17%
just photograph it and move on...
15
83%
Total votes : 18
Postby Ron Dickey » Thu Dec 09, 2004 9:08 pm
Ok folks how stringint are you. do you take notes so it you need to fix it you know what you did or are you the wild kind that that slaps it together and if it needs to be fixed you will deal with that then.
If other please state bellow
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 701
Postby Arne » Thu Dec 09, 2004 10:45 pm
I started out with the sketch to the left, here...... Did a bit of doodling, but that was it... mainly, I tried to be sure this step was right, and the next one would fit..... each wall, floor, roof was a project unto itself... but the overall plan was a sketch on graph paper for the general outline.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Steve Frederick » Thu Dec 09, 2004 10:57 pm
I must be really sick! :? I do 1, 3, and 4.. I have a notebook full of plan mod's and sketches. You've seen my photo journals. I used to keep a written journal of projects, like the boats. Trouble is, I can spend as much time writing as I do building. I like doing the journals as a way to help others to learn. And to pay it forward, for all those who have liberally shared their experience.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby asianflava » Fri Dec 10, 2004 2:39 am
The only recording I do is in my blog. http://asianflava.journalspace.com
I usually think about what I'm going to do and how to do it first. Paper is rarely involved unless I have to write down dimensions. When I finish that operation, I'll take a few pics and move on (back to thinking).
asianflava
Postby Arne » Fri Dec 10, 2004 7:05 am
Steve, I think your method is probably best.. Putting things down on paper makes you think. And, drawing, the same.... and that gives you time to consider what the final product should be like.
Arne
Mr. Subject Line
Images: 96
Return to User Polls
