Jigs and tables
did you create a Jig or mount or table for the Job?
Jig ... expand or show picture below.
0
No votes
Table ... saw horse ... pictures or describe below
2
67%
I saw a really good idea ....Expand.
0
No votes
Pullies or wentch
0
No votes
I made a tool ... joined several camps or welded a frame
1
33%
Total votes : 3
Jigs and tables
Postby Ron Dickey » Wed Jan 19, 2005 9:39 pm
In creating your teardrop did you create any Jigs or cutting tables that you would like to share.
Mike Came up with a building table ... and you??
http://www.mikenchell.com/images/step2.jpg
to bad you can not vote for more then one but you can add it below.
Maybe you have a tool or frame you used on your tear that you used at work or for other projects in your shop that you never really thought about until now.
Thank Ron D.
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 701
Postby Ron Dickey » Wed Jan 19, 2005 10:02 pm
In one of my woodworking mags it showed a spray booth. so fumes would not get every where.
This might work where you are using something that is flamable or like me your hotwater heater is in the same room.
PCV pipe cut to build and connected to frame corner joints
take clear plastic likt painters plastic ... but I think they used thicker plastic.
then they got zippers that comes with stickum tape on the sides ... stick it to the plastic and you have a booth with a zipper door.
Here is a huge one
www.oya.com/service/ paintbooth.html
here is one using close pins
http://members.thegateway.net/cfd/Airpl ... tbooth.jpg
they might help when you use those harsh glues if you are not outside.
Ron Dickey
Images: 701
Postby asianflava » Thu Jan 20, 2005 2:32 am
I can't find his website but a buddy made one of these booths. He used computer fans to exhaust it. I was busting his chops because they weren't the sprakless fans made for paint booths. He is building an RV7A (airplane) so he as to prime/paint parts as he goes along.
asianflava
Return to User Polls
