how did you attach most of the wood
connecting wood to wood with type of attachers mostly used.
dowels
0
No votes
nails
0
No votes
air stapeler
2
10%
sheet metal screws
0
No votes
wood screws
17
85%
wet rawhide strips tyed through holes
1
5%
Total votes : 20
Postby Ron Dickey » Sun Feb 20, 2005 1:42 am
When you build, building, built your trailer how did you attach the wood to wood.
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 701
Postby mikeschn » Sun Feb 20, 2005 9:41 am
I like using double joining methods whereever possible.
For example glue and screws
welding and bolts
Images: 471
Postby Ross Wade » Sun Feb 20, 2005 10:10 am
I total agree with Mike. I used Gorilla glue at all the major structure joints and then screwed them together.
Ross
Ross
Southern Appalachian Tearjerker Chapter Director
Ross Wade
Southern TearJerker
Images: 21
Postby ALAN GEDDES » Sun Feb 20, 2005 10:42 am
I use heavy duty construction adhesive and the longest presunk deck screws that will fit. And having just replaced the roof on tear 2 it is REALLY on there.
Alan
ALAN GEDDES
Images: 34
Return to User Polls
