fenders homemade or store bought
homemade
15
31%
store bought
31
63%
fenderless
3
6%
Total votes : 49
Postby droid_ca » Sat Feb 19, 2011 1:10 am
lets see your fenders needing some ideas
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Gage » Sat Feb 19, 2011 2:15 am
Well here's a picture of my fenders. '37 Chevy truck fenders (fiberglass).
Image Image Image
Gage
Images: 28
Postby 48Rob » Sat Feb 19, 2011 8:07 am
I chose fenderless...
<img src="http://im1.shutterfly.com/media/47b9d803b3127ccec739dd2502ea00000040O02AbNGjdu5bMge3nww/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/">
Visit Rob's World Web Page!
48Rob
Postby caseydog » Sat Feb 19, 2011 4:50 pm
Very simple fenders from Tractor Supply, to go with the minimalist theme of my TD...
CD
My build journal is HERE
caseydog
Images: 515
Postby mechmagcn » Sat Feb 19, 2011 6:43 pm
Aluminum Jeep type fenders from Tractor Supply
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
fenders
Postby mvperini » Sat Feb 19, 2011 11:44 pm
original 1947 fenders
Mike
1947 Kenskill teardrop kamper 4X10>
1951 Boles Areo 16ft Canned Ham>
1956 Roadmaster 20ft> Restored
1959 airstream 18ft restoration complete
1953 Pontiac house car
mvperini
Postby doug hodder » Sat Feb 19, 2011 11:58 pm
I've used Grants glass fenders on all my tears. Kit's, Modernistics, and the DeLuxe with the skirts, (first set of skirts made). You may or may not like the skirts on the Rocketear, but it fits the design. From a curb side appearance. I think a set of repop glass fenders are hard to beat and saves a lot of work and headaches. My opinion, the glass ones just have the correct look (vintage). Others opinions will vary. Doug
Postby Steve_Cox » Sun Feb 20, 2011 9:09 am
1947 Ford pick-up fiberglass fenders
Steve_Cox
Images: 196
Postby Woodbutcher » Sun Feb 20, 2011 11:08 am
Mine are fiberglass that I got from RW Johnson if I remember right,
Woodbutcher
Postby chorizon » Sun Feb 20, 2011 11:50 am
These are store-bought from TSC or Northern Tool.
Isn't this a GREAT PIC! :lol:
Here's a better one, I'm going to powder coat the fenders and the wheels pretty soon...
chorizon
Images: 94
Postby rmclarke » Fri Mar 18, 2011 4:45 pm
Mine certainly are not in the same league as the other ones posted here, but, since I'm on a budget, building my own was the way I went. Quarter inch ply built on a scrap jig, held together by epoxy glue fillets, then double epoxy coated, followed by 2 coats oil based enamel primer, then 2 coats of oil based deck and floor paint, and finally a coat of black undercoating....kind of labor intensive, but made from stuff I already had on hand from the trailer build.....works for me.
rmclarke
Images: 219
Postby Ron Dickey » Mon Apr 25, 2011 9:30 pm
cut mine out of wood stained and sealed!
these are the tops, made then under them I put ones that went at about 45 deg. left and right.
simple and cheep.
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 701
Postby halfdome, Danny » Mon Apr 25, 2011 10:21 pm
I have my steel fenders chromed at about $350 for the pair. That's over the cost of the fenders. :D Danny
halfdome, Danny
*Happy Camper
Images: 162
Postby jackdaw » Wed Apr 27, 2011 5:56 pm
I made my own as we haven't had a great choice at the right money over here.
This is a little faint, but I hope you can see whats going on
Next job was to cut the shape out, and transfer it to the celotex
I cut the shapes out using the band saw, and removed all the foil. I've used wooden skewers to hold the two pieces together.
I transfered a few lines onto the blanks to give a guide as to where to sand them into shape.
Using course sand paper, and a carving knife, It didn't take too long to get the desired shape.
Then it was just a case of making a mirror image for the second one.
I think they're ready for resin.
It took a couple of hours to get the two layers of mat made up on the mudguards.
After sanding off the high spots , they got a layer for black gelcoat added. Then easy fill body filler, then sanding and more sanding.
Well worth the £20 and a couple of days work.....
jackdaw
Images: 124
Postby slowcowboy » Mon May 16, 2011 4:46 pm
Slow has jeep fenders from northern tool.
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
6000 Club
6000 Club
Images: 166
Return to User Polls
