wiring begins where
my wires start. (Generater includes battery)
from my tow veh. under trailer to rear then in
1
9%
from my tow veh. to the front of my trailer then in
1
9%
battery in front then in
1
9%
battery in rear then in
8
73%
generator front then in
0
No votes
generator rear then in
0
No votes
generator sits outside
0
No votes
Total votes : 11
wiring begins where
Postby Ron Dickey » Mon Aug 01, 2005 9:26 pm
I may not get this right but you'll know what I mean
121377......134179
Ron Dickey
Images: 711
Postby darkroomsource » Tue Aug 02, 2005 7:27 pm
But it's more complicated than just that.
I have one set of wires that run from the tow vehicle to the marker and tail lights, plus ground - the frame is grounded and I ran a ground wire to each light.
I have another set of wiring for 12 V. From the battery to an auto fuse block, from the fuse block to the galley flourescent, plus one 12v outlet in the galley and two 12v outlets in the cabin, plus two overhead airplane-style lights in the cabin, plus an inverter (all positive wires go through the fuse block)
And another set of wiring for the 110V. It goes from the side of the trailer to an house circuit breaker box. Theres a dpdt switch that routes AC power from either the outside hookup or the inverter to the circuit breakers. There are three circuit breakers, one for the battery charger, one for the galley outlet, and one for the cabin outlets (2). All the outlets are GFCI.
And then there's the speaker wiring and power for the DVD/CD player.
-- Andy Hughes
My Teardrop
Grace Happens
darkroomsource
Postby bdosborn » Tue Aug 02, 2005 9:02 pm
I'm not in there either. My 12v wiring starts at the tow vehicle, goes to the battery on the front, under the trailer to the rear and in.
Images: 772
Return to User Polls
