Your galley is it the way you want it
I want to change my galley
The shelves are bare and I want to put in cabinets
2
9%
The handles are wrong
1
4%
I want to rearrange what cabinet is where
3
13%
The drawers are to small for what I want to use them for
1
4%
I have no electric hook ups or plugs
1
4%
The lighting is all wrong
0
No votes
I want to replace all my lights with LED's
2
9%
I want attachments on the main door so I can attach a inclosure on wet or cold days
2
9%
The stove is in a dangerous place and needs to come out or forward
0
No votes
I should have put in an ice chest
0
No votes
I should have put in a sink
0
No votes
I should have made the door higher
0
No votes
I will have to add more extending tables on the sides
2
9%
I need to design a wind block
2
9%
I need more drawers
3
13%
The galley is way to small for my needs
0
No votes
I have the wrong hinges on the cabinets
0
No votes
The doors get in my way
0
No votes
the drawers are to short
0
No votes
I wish I could detach the galley on once side and swing it to face the side of the trailer
0
No votes
I wish I could pull the galley out and simply put a different one in.
1
4%
The stove is all wrong
0
No votes
The ice chest is all wrong
0
No votes
I aimed the lights in the wrong direction
0
No votes
The gas hookup is all wrong
0
No votes
I should have used more wood
0
No votes
I should have used more metal
0
No votes
I need to make the trailer higher so I do not have to stoop
0
No votes
I want to put solar units in
0
No votes
I want to attach a shower to the sink
0
No votes
You left my change out see below.
3
13%
Total votes : 23
Re: Your galley is it the way you want it
Postby halfdome, Danny » Sun Jun 09, 2013 2:54 pm
Ron Dickey wrote:
halfdome, Danny wrote:I made a full sized layout to avoid any mistakes.
No need to make any modifications. ;)
:D Danny
what is you full size layout made out of .... did you make a galley out of cheeper wood, cardboard, built it on a computer. I have seen his Galley and it is very nice.
Ron
Ron,
A full sized layout is drawn with pencil and ruler/square in full size on a piece of cardboard, plywood or whatever.
If it's a 3/4" thick member then you draw it full size which is 3/4.
In other words draw in your drawers & everything else to the actual full size & be very accurate, it's worth the time and effort.
You draw the side section which is like looking through the galley exterior wall from the side with x-ray vision.
Call out all dimensions no matter how trivial it may seem & double check you math and your drawing.
You'll need to incorporate or consider the wall profile and lid profile so there are no issues when closed.
Grab a square piece of plywood or whatever, cut it the dimensions from the galley bulkhead to the rear of the trailer and the full height of the trailer at that point.
Now trace the exterior profile of your galley on it.
Now you have the foundation of your full sized lay out.
If you draw it out this way, and the face view (another piece of material), you'll get exactly what you planned, if you follow your layout to the "T".
:D Danny
halfdome, Danny
*Happy Camper
Images: 160
Return to User Polls
