What type Side/dressing tent for your teardrop?
Postby Rlowell » Thu Feb 06, 2014 9:39 pm
I do not remember this poll. What type of side tent or dressing tent do you use?
Did you buy one from wallyworld or did you build it yourself? Lets hear your good and bad experiences.
What do you think?
Rod :thinking: :thumbdown: :thumbsup:
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Re: What type Side/dressing tent for your teardrop?
Postby PKCSPT » Thu Feb 06, 2014 10:16 pm
I bought a tent on Amazon, works on SUV's, it is in my pics below. This one was cheap, easy for me to put up and roomy.
I am sure this was asked before but I don't mind when questions get re asked
121172 116946 159644
PKCSPT
Images: 61
Postby GuitarPhotog » Thu Feb 06, 2014 10:41 pm
Built my vestibule myself from a frame made from 1/2" EMT conduit (thanks Gordon Burwel), and Harbor Freight tarps. I intend someday to replace the tarps with sewn awning material, but haven't yet.
The big blue tarp is supported at the open end by a couple of REI Tarp Poles.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Gage » Fri Feb 07, 2014 3:18 am
Here's what my sister has for her KIT Kamper. Made by Marti of Marti's Awnings.She does fantastic work and very reasonable, can’t be beat. :thumbsup: An all weather addon. ;)
Image Image Image
Gage
Images: 28
Postby rowerwet » Sun Feb 09, 2014 7:11 pm
109769
created my own for cheap, We won't go anywhere without them.
the link is in my signature
rowerwet
Images: 521
Postby KennethW » Sun Feb 09, 2014 7:47 pm
111190113383 click to enlarge
I built the dressing room support tubes in to the roof. Just pull out and hang a couple shower curtains up.
KennethW
Images: 82
Postby rowerwet » Mon Feb 10, 2014 8:14 am
KennethW wrote:111190113383 click to enlarge
Are the tubes inside waterproof? My front curve wouldn't let me do it that way, and my roof height isn't tall enough. if I had a roof rack it would work as a pull out, but the rings would have to be shallower as the tubes would hit each other when pushed in. I could make it with four tubes to slide into... :thinking:
rowerwet
Images: 521
Postby KennethW » Mon Feb 10, 2014 1:06 pm
There is 4 tubes 2 for each side. The tubes are between the roof skin and the ceiling skin. Yes, the tubes are sealed on the inside.
KennethW
Images: 82
Postby rowerwet » Mon Feb 10, 2014 4:15 pm
KennethW wrote:There is 4 tubes 2 for each side. The tubes are between the roof skin and the ceiling skin. Yes, the tubes are sealed on the inside.
rowerwet
Images: 521
Postby Java Jack » Tue Mar 17, 2015 3:03 pm
I just posted a video in the General Topics section on the side tent my wife and I modified.
We started with a Lightspeed Privacy tent and modified it so that we could attach it to the side of our teardrop.
Video is here:
Full project pictures are here:
http://imgur.com/a/X7p4P#0
There are 10 types of people in this world, those that understand binary and those that don't.
Regards,
Java
Proud Owner of a CampInn 560 Ultra
Blog: http://cre8tiveapps.blogspot.com/
Video: https://youtu.be/TLLFt3vzFoA
Sill Images: http://imgur.com/a/EE0zC#0
Java Jack
Postby GerryS » Wed Mar 18, 2015 4:44 am
I love this....I was concerned with ease of setup but that tent is as easy as an umbrella! How does it stand up in the rain? I've had a couple collapse when rain starts to pool in the roof....
I think I would look at using the clips/hooks that campinn uses for their side tent, which we have. But it's probably on its last season...as opposed to suction cups. I've tried using the same cups and the adhesion was just not reliable enough.
GerryS
Postby Java Jack » Wed Mar 18, 2015 7:09 pm
Last weekend was our first trip out since making it so no data on rain.
It did hold up in the fairly breezy mornings we had out there. I am still thinking about how to make a rainfly for it as the tent is only water resistant, not water proof. The roof is fairly taught so I don't expect any water pooling on it.
Also, since it was originally designed as a shower tent, the roof is designed to support a 5 gallon solar shower bag so even if there were pooling, it should support a fair amount of weight.
However, Lightspeed does not offer a rainfly at this time so I really need to figure that one out on my own.
Regards,
Java
Java Jack
Postby Java Jack » Wed Mar 18, 2015 7:48 pm
Regards,
Java
Java Jack
Postby GerryS » Thu Mar 19, 2015 4:30 am
Looks like we have two threads on this... The problem isn't weight inside..it's weight outside...does rain pool and stretch the roof. The price isn't bad here, may try it anyway and see if I can customize a solution.
This looks good.
I see you are not extending the leg by the fender...it looked like you were resting the foot on the fender. Are the leg lengths that adjustable, or, did you have to trim?
Besides water on the roof....level ground has been the second Achilles heel of every side tent I've looked at...
GerryS
Postby dales133 » Thu Mar 19, 2015 6:04 am
I'm looking at getting a bag awning like this but with solid walls.
Realy need decent shade here in aus and you can install the walls or just use the awning
http://www.oztrail.com.au/product-range ... by-oztrail
dales133
Return to User Polls
