hinge what type did you use for outside doors
Hinge I used on my outside trailer door were
Piano Hinge
5
42%
Reg. Door hinge
3
25%
Hinge I made my self (hopefully pictures below)
0
No votes
mine is a slider
0
No votes
no doors we go in and out the hatch
0
No votes
non of the above see below
4
33%
Total votes : 12
Postby Ron Dickey » Sun Jul 20, 2014 10:37 am
I use a commercial hinge, which stick out side but can not have the pin removed with out a grinder.
What did you use and pictures would be nice for those who are building.
Ron
you have 2 choices for those who have an unusual set up
but you can not revote so if you change the hinge add it below.
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 707
Re: hinge what type did you use for outside doors
Postby working on it » Sun Jul 20, 2014 2:15 pm
I used gate hinges because they are strong (built to hold heavy gates), durable (nylon bushings and powder-coated), secure (fixed pin design), and black (to match the color scheme). Readily available anywhere (HD, Lowes, TSC, internet, hardware stores, etc.) if ever a replacement is needed.
gate hinge-fixed pin, nylon bushings, powder-coated.jpg (29.84 KiB) Viewed 4413 times
Here is part of a post I made outlining my reasoning for the choice of these heavy-duty hinges :
working on it wrote:... I'm a shadetree mechanic looking to make my own innovations, just to see what'll work and not, function not form. In defense of my solid one-piece doors: If you spread the loads caused by the act of closing/sealing the doors, and waterproof them, then future problems should be nil. Though my cut-out doors are of non-standard shape, I endeavored to spread the loads/forces involved for a tight, even seal all around. I spent some time figuring the most well-distributed loading points before I added the hinges. I did the same figuring the optimal placement for the dual-locks.
triple hinges, dual door locks.jpg (140.73 KiB) Viewed 4413 times
I used three heavy duty gate hinges with nylon bushings, and bolted them on. There will be no sag, considering the light weight of the doors. The slide-locks were chosen for security and to further spread the load. Sealed high and low, the doors are held firmly against the routed interior framework and automotive door-seal. I keep them tightly shut at all times; can't warp if they're held flat!....
Overkill, yes. But I doubt they'll ever get "loose" or wear out. I even used three more to hang my vertical hatch.
triple hinged hatch.jpg (45.34 KiB) Viewed 4413 times
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2220 lbs
156215157958148599
working on it
Images: 455
Postby Fyddler » Sun Jul 20, 2014 5:30 pm
I used gate hinges, but they seem to be rusting a bit, not a big issue yet but it seemed odd to me that something designed to be used outside would get rusty.
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
Postby citylights » Sun Jul 20, 2014 5:47 pm
Fyddler wrote:I used gate hinges, but they seem to be rusting a bit, not a big issue yet but it seemed odd to me that something designed to be used outside would get rusty.
I used stainless steel gate hinge from lowes. It has been a year now and it is great so far.
citylights
Postby Toytaco2 » Mon Jul 21, 2014 8:05 pm
I used chrome plated "topedo" style hinges. The crappy little dry wall screws in the picture were only used for initial fitment of the doors. They are now replaced with stainless steel square drive hardware...so no rust. The hinges allow the doors to be lifted off the TD similar to the way the old Jeep CJ doors worked. I'd definitely do it this way again. I used two hinges per door, although I've also seen it done this way with 3 hinges per door.
Mike
Toytaco2
Images: 367
Postby tac422 » Tue Jul 22, 2014 6:39 am
I used these hinges, but my door is very light .
http://www.lowes.com/pd_40467-1277-8386 ... facetInfo=
tac422
Images: 222
Postby jss06 » Tue Jul 22, 2014 7:41 am
I used the same hinge Working On It used. They are very sturdy and work great.
jss06
Palladium Donating Member
Postby len19070 » Tue Jul 22, 2014 8:17 am
I basically use a Piano hinge but with a little addition.
This hinge with the 1" ID "C" channel is available Locally at any place that Makes Storm Doors for about $35 for an 8' section. Notice I said "Makes Storm Doors", your not going to find it at Home Depot.
It works out very well, you make the door, install the hinge in the jam, insert the door into the "C" channel on the hinge, adjust it then pin it.
Happy Trails
Len
len19070
Images: 24
Postby halfdome, Danny » Tue Jul 22, 2014 7:46 pm
I use what Grant Whipp of Teardrops.net Sells. http://www.teardrops.net/teardroptrailerparts.html
:D Danny
halfdome, Danny
*Happy Camper
Images: 188
Return to User Polls
