you guys can now upload all your cad designs
Postby mikeschn » Sun Feb 26, 2012 2:00 pm
Here's a brand new section for you guys... Sketchup designs.. you guys can now upload all your cad designs.
I've set it up so it can handle skp, igs, dxf, sat and dwg. If you need a different file extension, let me know and I'll add it.
Meanwhile, will someone please test it for me with a sketch up file?
Thanks,
Images: 479
Re: you guys can now upload all your cad designs
Postby parnold » Sun Feb 26, 2012 2:09 pm
I got this while trying to upload a sketchup file.
413 Request Entity Too Large
My small attempt was 244kb my big attempt was 2.22 Mb
parnold
Images: 302
Postby parnold » Sun Feb 26, 2012 2:11 pm
This was the smallest sketchup file I could find. 92kb.
framedin.skp
Old early sketch of my 1st tear
(91.71 KiB) Downloaded 315 times
parnold
Images: 302
Postby mikeschn » Sun Feb 26, 2012 2:21 pm
Okay, I got the same error, it appears to be a nginx limitation. I've turned in a trouble ticket.
I'll let you know when it works for larger files.
Images: 479
Postby parnold » Sun Feb 26, 2012 2:31 pm
I hope you have a big hard drive in that new server.
:FNP
parnold
Images: 302
Postby mikeschn » Sun Feb 26, 2012 2:34 pm
parnold wrote:I hope you have a big hard drive in that new server.
:FNP
I was just thinking about that. I have a 60 gig harddrive in there. There's about 30 gigs available right now. If the average file size is a couple megs, then we have room for 15,000 uploads. Think that'll work for a little while?
Images: 479
Postby parnold » Sun Feb 26, 2012 2:49 pm
Sounds like it will due for a little while. I don't know about average size, my 2.2 mb file actually has about 6 different renditions of my 2nd trailer build so it may be above average.
parnold
Images: 302
Postby synaps3 » Mon Feb 27, 2012 12:16 pm
I replied in the announcement, didn't see this thread...
synaps3 wrote:I attempted to upload my .skp for The Pup's Penthouse, but I got an error:
The file is 10.1MiB (10,633,475 bytes) and has the filename Pup's Penthouse.skp
I added it as an attachment to my post then tried to upload it. Is there another way I should have done it?
-- Dave
Build log: here
synaps3
Images: 254
Postby pohukai » Mon Feb 27, 2012 12:24 pm
my google sketchup file is over 8megs and extremely detailed; including some wiring runs. It's a lot cheaper to make mistakes electronically.
pohukai
Images: 9
Postby mikeschn » Mon Feb 27, 2012 5:50 pm
I have a trouble ticket turned in. They are working on it.
Images: 479
Postby elmo_4_vt » Mon Feb 27, 2012 7:02 pm
Not sure how much I can contribute at this time.. But, can it accept (or be made to accept) .dgn files? I use MicroStation pretty much exclusively.
Don
Truck: '96 Ford Bronco, Modified for off-road stuff
Trailer in progress: Not a tear drop exactly, sort of a mut of a couple different designs.
elmo_4_vt
Postby mikeschn » Mon Feb 27, 2012 7:57 pm
elmo_4_vt wrote:Not sure how much I can contribute at this time.. But, can it accept (or be made to accept) .dgn files? I use MicroStation pretty much exclusively.
Don
Can you export to step, sat or parasolid? Those would be preferred. DXF and IGES might also work...
Or you could download the free version of Sketchup and play and make models with that. That's what I doing. Currently reviewing the 888 page manual. :?
Images: 479
Postby mikeschn » Tue Feb 28, 2012 11:17 am
Would someone upload a larger skp file as a test for me? Larger than 1 meg, and smaller than 10 meg. I don't have anything with me, and support thinks they have it fixed. But I'd like to know for sure.
Images: 479
Postby danlott » Tue Feb 28, 2012 7:44 pm
Just posted one in a new topic Mike. I think it worked.
Dan
Hoplite Traveler Build thread
danlott
Images: 262
Postby mikeschn » Tue Feb 28, 2012 8:03 pm
Thanks for testing that Dan, it worked. :thumbsup: And it's larger than a meg! :thumbsup:
I just tried to test it further, and it said 2 meg was my maximum upload size... :cry:
Just turned in another trouble ticket! :duh:
Images: 479
Return to Sketch up designs
