12' Trailer Design
12' Trailer Design
Postby Bengrey » Tue Apr 19, 2016 11:30 am
Hello all, I've been lurking on these forums for the last few months and have finally designed my own trailer. Granted this is only the framework, with windows and doors for reference, but this is what I intend to use for my build-out
Dimensions are 12' long, 7' wide, 6' max height
Let me know what you think!
141045
Bengrey
Images: 10
Re: 12' Trailer Design
Postby Gator417 » Fri Apr 14, 2017 2:24 am
Looks great BG. I'm thinking through the design of a 12x6 right now myself. So many options! For yours, I would put the door in the center at the rear, just so I could slide my Goldwing down the middle, plus have cabinets on either side. Good luck to you.
Gator
"Aluminum skinning is to cover rotting prone crappy plywood"
linuxmanxxx
Gator417
Postby Andrew Herrick » Fri Apr 14, 2017 8:34 pm
Bon voyage, as they say!
Whatever would we do without SketchUp, amiright?
1. I'm assuming you've mocked up a frame using wooden 2x2's, not 2-inch square metal tubing. If so, have you considered the best joinery techniques? Personally, I'd recommend pocket screws. You have joints with 3, 4, even 5 members mating, and that's a bear to do with traditional wood joinery techniques - and I don't even want to imagine the clamping jigs.
2. Front-facing windows tend to leak the most, and unless you detach your tow vehicle from the camper, you don't get much of a view. Even moving the window to the angled portion on the front might fix both of those issues.
3. Speaking of which, I'd add in a spanning member on that angled portion. That's a huge gap. I don't know what you're using for roof sheathing, but you should factor in snow loads. If you park this thing outside, and it gets hail/snow/tree limbs on top, it doesn't look like you having enough cross members in there to support heavy loads, especially if you're going with 1/4-inch, even 3/8-inch sheathing. And since your roof is flat, with no curve anywhere, any deflection means that water is going to puddle on your roof and sit there, so you want as little deflection as possible.
4. Judging by the 7-foot width and framing design, I assume you'll be recessing your wheels? Plan ahead! If you want to use fenders, they come in standard sizes. 9x32 is the standard for round fenders for 13-15 inch wheels. But it's also not too much trouble to make your own wheel wells. When sizing your wheel wells, I'd make them large enough to accommodate 15-inch wheels. You don't need wheels that big, necessarily, but it's a nice option to have.
5. You probably already know this, but since you're over 80 inches wide, and you're six feet tall, you technically need additional exterior trailer lighting to comply with federal DOT regulations. You can run some of this wiring through your 2x2 frame.
6. Also, I'd look on eBay for surplus RV windows. You can find some big ones for some amazing deals. Shipping is expensive, but still, costs half as much as buying new windows. Those windows in your mock-up are, what, four feet wide? That's $$$$ if you purchase them new. Also, if you use RV windows - which I'd heavily advise, because house windows aren't tempered the same and are prone to breaking, leaking, and fogging up - you don't have to pre-frame the structure. RV windows use an interior clamp ring to secure the window. You don't need to screw around the perimeter.
6. The devil's in the details, as they say. You have a great start. Good luck!
A few of my builds:
Andrew Herrick
Images: 15
Postby neogenesis » Mon May 01, 2017 4:16 am
You might really like some of the resources I just shared in my recent post.
viewtopic.php?f=2&t=68422
neogenesis
Return to Sketch up designs
