Thanks for the advice to get this plywood.
That's what this forum is all about. Something like pay it forward.
closecuddlin wrote:I am building my 1st teardrop. I am using various thickness of Baltic birch throughout. Its a 5 wide x 9 long box. I am planning to use 1/8 " as an outer skin, covered by a double layer of Upol brand spray on bedliner coating over the entire outer surfaces, masking off the doors, roof vent, frame rails. I'm using TB III on all wood to wood joint areas and the outer vertical edges to the roof skin . I dont like the looks of the aluminum trim molding at that area and was wondering if any one has another idea what I can do to make that seam waterproof, and if you think I should double up the roof skin by bonding a second layer of 1/8" onto the first one. ..or not? Has anyone ever heard of bedliner coating used on a teardrop? I dont mind the irregular surface and It would actually seal up what the cartridge sealer misses. Thanks...Steve in Oregon
