Sparksalot wrote:If you've ever seen how stitch and glue boat building works with the exact materials you mentioned that could be an option. I'm in the middle of it with a kayak right now.
I could envision using staples to hold the roof to the spars as glue sets. Remove the staples after, and then glass/epoxy. From more the inches away, the staple holes will disappear.
tony.latham wrote:Good question.
You might consider stainless flat head screws countersunk and spaced every 3". I think it'd give a nice finished appearance.
T
Would I be able to countersink screws in plywood that’s just over an 1/8 thick?
nik1093 wrote:
I like the idea of this. I was imagining that once it was glassed and epoxied, you wouldn’t need to rely on mechanical fasteners between the roof ply and spars.
Toytaco2 wrote:Someone on this forum recommended the following a few years back and I used it in my build. I used 1/4 inch crown staples to hold the roof ply in place shooting the staples through some of that poly stripping used in shipping packaging. After the glue dried I was able to pull the stripping off and the staples came right out with it. Obviously you don’t want your staples to be too long and you want to run some tests prior to using in your build. Worked for me.
Mike
