MudFlap wrote:I've read that some use minimal water. Maybe a small bucket or perhaps even a spray bottle. Apply water to sanding block or surface to be wet sanded, sand away for a bit, wipe up with paper towels, another squirt and wipe for a final rinse and move to next spot.
Is that sufficient?
So what's wrong with being a neanderthal?
tony.latham wrote:their tools were a bit on the low-tech side. (Did you try scraping the fiberglass with a rock?)
But they camped in caves... Humans camp in teardrops.
Is that normal? Does it mean that my fiberglass will fly off when I least expect it?
MudFlap wrote:The only thing that didn't go quite as expected is I picked up a healthy "orange peel" texture with the fill coats. ... Is that normal? Does it mean that my fiberglass will fly off when I least expect it? haha
Since I'm working on vertical walls, I *think* that I have no choice but to roll on the epoxy.
MudFlap wrote:Thanks for your help Tony.
One stressful part of this process is that once you pour the hardener into the epoxy, clocks start running.
On the first video I posted above, I was surprised that the girl mixed up a batch of epoxy, let it sit around for a while, then leisurely broke out the heat gun and zapped the bubbles in the mix cup. Heck, once I'm done mixing the epoxy, I'm practically running to the camper to get the epoxy applied ASAP. Of course, all the girl needed to do with her epoxy is pour it into a mold. How long does THAT take!
But as you've said, we're not launching rockets here, and it does appear that the process is a little more forgiving than one might expect...
I was surprised that the girl mixed up a batch of epoxy...
