Questions about Aluminum Trim
Finishes, paints and coatings
Postby drewh1 » Fri Jan 10, 2014 4:53 pm
I am getting ready to skin my project in aluminum (build - Heart of Gold). I would like some advice about what trim to use.
I don't want to use the edging with the vinyl strip insert so I see the following options:
1 - Teardrops trailer.net has 9' sections of body edging, measures 15/16th by 1/2 in. Says it is very easy to bend. The 15/16. I like that it comes in 9' sections although it is still too short for single piece along my roof edge. the 15/16th is also a bit wide for my hatch edging.
2 - teardroptrailerparts (vintage tech) has a 7/8th by 1/4" in 8' sections that I could use everywhere including the hatch seal edge.
3 - Lil bear has a variety of edging but seems quite a bit more expensive than the other alternatives.
Also wondering if I can use flat stock aluminum edging for the bottoms or should I use the the regular edge trim with the lip overlapping the bottom edge?
I would appreciate hearing from any of you that have used these trims and get your impressions and recommendations.
Thanks,
drew.
"If only I knew what I know now when I started . . ."
My Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=56916
drewh1
Images: 7
Re: Questions about Aluminum Trim
Postby Irmo Atomics » Sat Jan 11, 2014 5:08 am
I used a lot of flat stock that I got at a local metal distributor - it was in 20' lengths but they cut it to what I needed and sold it by the pound. I got my drip rail and 90 degree trim from a local RV dealer that does RV repair. What they didn't have in stock, they were able to order pretty quickly - it was 15 ft lengths.
99676
Bob
Irmo Atomics
Images: 64
Postby drewh1 » Sat Jan 11, 2014 9:38 pm
thanks for the info and the photo, very helpful to see how the trim was done.
drew.
drewh1
Images: 7
Postby tony.latham » Fri Jan 17, 2014 10:31 am
My own take on it is that you need to have the lip on it and set it down over a good bead of GE Silicone II (not the first gen). I had the same problem with lengths and butt joined it and it came out fine.
Tony Latham
Postby citylights » Fri Jan 17, 2014 10:58 am
Wow I had the exact same questions. You just don't know until you get some experience with it.
I liked the RV edge trim for everywhere I had to bend it. Very easy to bend. I used it for the front, roof, and galley rounded edges.
I used 1 inch angle for all the unbent pieces. Lower edge, front bottom edge. Lots of small end pieces.
I also used the 1 inch angle for around my door jam trim. Really hard to bend! Took me all day to beat each door in place with a rubber mallat. There has got to be a better solution for that!
For around the doors, I used grants T molding, that worked great and easy.
I used 3/4 butyle tape for everything except the doors. On those I used a silicone sealant. It was thinner and easier to make the doors look good. But I assume it won't last as long.
Check me build thread, lots of aluminum working pictures.
citylights
Postby drewh1 » Fri Jan 17, 2014 12:01 pm
thanks Tony and John. I am starting to get an idea of what I need.
citylights wrote:Check me build thread, lots of aluminum working pictures.
I have gotten alot of good information from your build thread John - You did an amazing amount of aluminum work and edging. The Cooler really looks great and will last for 100 years!
drewh1
Images: 7
Postby danlott » Fri Jan 17, 2014 5:11 pm
You should contact Grant at Lil Bear Tag-Alongs http://www.lilbear.teardrops.net/index.html
He lives up in Redding which is not to bad of a drive for you. He should be able to help will all the trim you need.
Dan
Hoplite Traveler Build thread
danlott
Images: 258
Postby drewh1 » Wed Jan 22, 2014 2:49 pm
Ok - I ordered trim and aluminum sheets! pretty exciting place to be in my progress. i have a couple of questions.
Do I need a speed controller to use the edge trimmer in my router?
Should I use the laminate bit or a bearing edge bit?
drewh1
Images: 7
Postby tony.latham » Sun Jan 26, 2014 11:32 am
I thought about buying a router speed control and didn't. I didn't have any problems with the speed. I've got a aluminum sheathed tongue box project in the shop right now and still no regrets.
You need a laminate trim bit with a bearing on it. I think they are only made with the bearing.
Trimming 040 aluminum is not a challenge with this system. I covered my aluminum with masking tape to avoid scratching it where the router base rode on it. You don't want to get a sharp piece of aluminum under it and drag it across the sheet.
Postby Esteban » Sun Jan 26, 2014 12:22 pm
What size and shape of aluminum trim is preferable to use for the sides of the galley lid?
I will be fiberglassing then painting my teardrop including the outside of the galley lid. I will need trim on the sides to keep rain and moisture out. I imagine a L shaped trim should be used. The side walls in the galley will be 1-1/8" thick/wide if that makes a difference in choosing the right trim.
Steve - SLO, CA
Esteban
Images: 15
Postby drewh1 » Sun Jan 26, 2014 3:37 pm
tony.latham wrote:I thought about buying a router speed control and didn't. I didn't have any problems with the speed. I've got a aluminum sheathed tongue box project in the shop right now and still no regrets.
Thanks Tony! I cut some pieces on my miter saw without a problem. I'll skip the speed controller then. I have a couple of edging bits with bearings so should be ok.
Here is the aluminum . . .s
drewh1
Images: 7
Return to Skinning secrets
