bedliner paint job
Finishes, paints and coatings
bedliner paint job
Postby Toyotamike » Mon Apr 07, 2014 8:34 am
This was recommended to me to help seal the tear and I was already considering it anyways to match the tow vehicle. I found some do it yourself ones with color choices. Problem now is choosing what color and smooth or textured.
http://www.nonslipcoating.com/colorchart.htm
Toyotamike
Re: bedliner paint job
Postby SLUG36 » Mon Apr 07, 2014 11:31 am
OOH, AHH, thanks for the link. I was debating on using bed liner for my roof. the "SMOOTH" would be great. and now to pick a color.
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Postby kayakdlk » Mon Apr 07, 2014 1:14 pm
I would suggest checking out Monstaliner and see how it compares. I decide to use Monstaliner after much research. 2 part, UV stable, any color (if you use auto pimgment tint)
Dan
kayakdlk
Images: 392
Postby Toyotamike » Tue Apr 08, 2014 1:00 am
I liked this brand because it has the UV protector in it and there is no mixing.
Toyotamike
Postby hmikey » Fri Apr 11, 2014 10:23 am
Hi: A similar product is called "Grizley Grip". I wouldn't know if one is better than the other but, its nice to compare.
hmikey
Postby Starseeker » Wed Apr 23, 2014 7:47 am
I wonder if this will be a viable alternative compared to using Filon. From what I see, you throw on a couple of layers of smooth texture and you get waterproofing, UV protection, and color all at once. Another plus would be that this stuff can take a heck of a lot of abuse.
Aaron
KF5VBV
Starseeker
Images: 10
Postby SLUG36 » Wed May 28, 2014 6:54 am
Toyotamike wrote:This was recommended to me to help seal the tear and I was already considering it anyways to match the tow vehicle. I found some do it yourself ones with color choices. Problem now is choosing what color and smooth or textured.
through the website, I ordered a sample of the non textured liner. It seems a little too soft and pliable, and I could gouge the coating with my thumb nail. It reminded me of the rubberized dip coatings you can buy in small cans.
I was hoping for a more rock solid liner more like the "Line X" in my GMC's bed. I would suggest requesting a sample and make your own assumptions. :thumbdown:
SLUG36
Images: 137
Postby Toyotamike » Fri Jun 20, 2014 1:04 am
Yeah but it seems line X is the only brand that has that rock hard finish. Rhino liner, herculiner, ect are all more rubbery. I did get a sample and I had to use a fork to gouge it. Think a few layers or a thicker coating might help this.
Toyotamike
Postby bherron1 » Thu Apr 14, 2016 6:04 pm
I got samples of durabak in forest green smooth and texture to paint my jeep and ttt its hard as a rock and tough as a nail. Call them and get u a sample.
bherron1
Return to Skinning secrets
