my exprience with RAKA epoxy
Finishes, paints and coatings
Postby 65rbdodge » Tue Jun 03, 2014 12:09 pm
I just finished skinning my bare wood TD with RAKA 3.25oz fiberglass cloth and epoxy. I laid out all the pieces and cut them to fit, holding them in place with thumb tacks/pushpins(overlapping about 2" at all the seams). I bought the pumps to fit the epoxy bottles from RAKA(this worked great and made it really easy to mix) 4 pumps epoxy to 2 pumps hardener gave me the correct amount to work with before it started to harden to much to work with. depending on what surface I was working on I either poured it on or brushed it on and spread it out with a bondo spreader. it soaked right through the cloth and into the wood. I had no problems what so ever, it was quite easy. I had rubber gloves on the entire time I was working and mixed the epoxy in a paper or Styrofoam cup and threw it away when I was done.
65rbdodge
Re: my exprience with RAKA epoxy
Postby 48Rob » Tue Jun 03, 2014 6:28 pm
Sounds good! :thumbsup:
Thumbtacks are a great idea, that's one I need to file away...
Can you share any pictures?
Rob
Visit Rob's World Web Page!
48Rob
Postby danlott » Wed Jun 04, 2014 10:08 pm
I also like the thumb tack idea, will use that for sure.
Thank you,
Dan
Hoplite Traveler Build thread
danlott
Images: 258
Postby 65rbdodge » Thu Jun 05, 2014 6:52 am
here it is, I didn't take any pics with the cloth on before I put on the epoxy-
I still need to put another coat of epoxy on to smooth it out/fill it in some more.
65rbdodge
Return to Skinning secrets
