list of what you can skin with?
Finishes, paints and coatings
Postby slowcowboy » Sat Aug 30, 2014 5:09 am
lets list what a guy can skin with here all types.
I am in the process where I am way early and able to decide what I can skin with.
whats all out there for options to put on a skinning list?
slowcowboy
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Re: list of what you can skin with?
Postby Danidog » Sun Aug 31, 2014 9:09 am
What is the definition of 'skinning'? Is it any material used as a protective or strengthening cover for a different material? I ask because I'm trying to finalize what I'll be doing for my TTT next week. I'm intrigued by the canvas covering over plywood. Is it 'permanent' and does it stop plywood checking or just cover it up?
Thanks for posting this ?? slowcowboy, I'm watching with interest, hoping to learn more.
thanks,
Dan
Danidog
Postby fm-usa » Wed Nov 11, 2015 9:52 pm
Last post was a year ago.
Everyone keeping there secretes to themselves?
I too am interested in this question.
PM me if there's a problem, I don't want to be a toe-stomper.
Is it possible, FULL RV in a 48 Sq.Ft. footprint & stay under 500Lbs wet?
SHE thinks teardrops are "cute" but I prefer a SKOSH mo-room & at 65+ the
body doesn't react/extract/move/mend/bend/lend or work like it use'ta.
NOW! Those unwanted guests moving in, Mr. 'Arther I. Tus' & Ms. DVT (grrr)
fm-usa
Location: ILLinois_60085 ================= Floyd_&_Debbie_+_Bailey
Postby Brushy_Bill » Thu Nov 12, 2015 12:29 am
fm-usa wrote:Last post was a year ago.
I got to this party late, only getting interested in
teardrops earlier this year.
Many threads are very old and not active for a year
or more.
While there is some good info available here, I have
found many, many links that are dead in a lot of threads.
It sucks to do a search, have the joy of finding a hit,
only to find a dead link that supposedly held the answers
to your questions.
Brushy_Bill
Postby fm-usa » Thu Nov 12, 2015 12:37 am
Ya, kinda caught that scenario on old threads.
I did read a lot and did searches.
EH, I tried.
fm-usa
Postby dguff » Thu Nov 12, 2015 11:19 am
Ok, here is one list, may not be complete but some ideas.
house paint
auto paint
polyurethane
shellac
varnish
epoxy
canvas
painted canvas
resin
fiberglass
waterproof vinyl
aluminum
stainless steel
copper
rigid plastic such as filon
plastic drop cloth
truck bed coating
must be others
Jerome
2008 Guffman
dguff
Images: 69
Postby Rferg800 » Thu Nov 12, 2015 11:26 am
Ya was thinking about that truck bed coating. Around here I think it is called Rino Lining . Its sprayed on. Has anyone used it as under coating?
Rferg800
Postby DrCrash » Thu Nov 12, 2015 2:28 pm
Rferg800 wrote:Ya was thinking about that truck bed coating. Around here I think it is called Rino Lining . Its sprayed on. Has anyone used it as under coating?
I did mine in " Spray on Rhino lining " Look in my photo album the silver teardrop. Yes I would do it again, yes it was expensive to do. PM me any questions
DrCrash
Images: 51
Postby Jharris1385 » Thu Nov 12, 2015 2:58 pm
With your liner, what did you do around your doors and windows? Did you spray after install or before? Im curious about the thickness of the liner hindering the trim and frame of door/window.
Jharris1385
Postby tlsallada » Thu Nov 12, 2015 3:45 pm
On my teardrops I've used FRP for the roof and galley hatch with great success. On my larger builds I've used it for the entire exterior (Sides, roof) and it makes a great, maintenance free, easily washed or painted surface.
137259
tlsallada
Images: 10
Postby Flying Teardrop » Fri Nov 13, 2015 10:15 am
I'm still in the planning stages, but at this point I think I'm going to use paint over the plywood skins. One of the following products:
http://protective.sherwin-williams.com/ ... oduct-6795
or
http://www.sherwin-williams.com/homeown ... 1131783261
I plan to keep my teardrop trailer in a barn when I'm not camping in it.
David
Flying Teardrop
Postby fm-usa » Fri Nov 13, 2015 10:40 am
I too am in the planning stages and looking for the lightest skin that's also waterproof.
Being lightweight, the paint used should be pliable to keep from cracking.
Sears had a Weatherbeater paint that dried to a firm rubber. But that was bad to the house used since water got under the skin and rotted the wood. Curiously I took a piece and folded it over, it did not crack, it didn't even make a sound when held to my ear.
fm-usa
Postby Sheddie » Fri Jan 08, 2016 11:40 pm
I used ACL. Aluminium Composite Laminate.
It has a few other names as well, but is a product commonly used in the sign writing industry. It is also being used a lot for cargo trailers and truck bodies. Here in New Zealand we have it available from several manufacturers, usually in 3mm or 4mm thicknesses. It is made up of (in the case of the 4mm that we used), a sheet of about 3mm plastic composit, with about 0.5mm of aluminium laminated on each side with painted (or powder coat) finish on both sides, or with the sheet I used on the roof was white on one side and "mill" (bare alloy) on the other. The side sheets we used were red on one side and yellow on the other, we used the red side. The sheets come in a variety of sizes from the usual 1220x2440 (8'x4'). I used 3m x 1.5m sheets for the sides and a 4.8m x 1.5m for the top. This one went from the drawbar all the way over the roof and down to the bottom of the hatch.
It is rasy to work with, it curved over the roof and hatch easily and if you want to put sharp bends in it you just rout a groove in the back of the bend. Cutting is easy with any sort of saw or a router, or you can use a Stanley knife and snap it. l used jig saw and a multi tool.
Would I use it again? Without hesitation! :thumbsup: I was easy to cut, just glued on the sides, top was glued with screws around the perimeter, covered by the alloy trim.
It was really quick as once it was cut and glued on it was finished.
As it is used in the sign writing industry, it is made to withstand the out door elements.
109727 109728 109736 109741
Sheddie
Images: 1129
Postby rowerwet » Sun Jan 10, 2016 6:28 am
Danidog wrote:What is the definition of 'skinning'? Is it any material used as a protective or strengthening cover for a different material? I ask because I'm trying to finalize what I'll be doing for my TTT next week. I'm intrigued by the canvas covering over plywood. Is it 'permanent' and does it stop plywood checking or just cover it up?
thanks,
Dan
It is permanent, the plywood will not check underneath as it will not weather. If removed the fabric will tear off the top wood layer with it.
Follow my signature link to find the instructable with plenty of pictures.
rowerwet
Images: 521
Postby fm-usa » Sun Jan 10, 2016 7:40 am
thanks,
Dan
Canvas over ply. I had scrap drop cover and leftover paint, so doing a test was a no brainer.
Yes it will take the top layer off.
fm-usa
Return to Skinning secrets
