Page 2 of 3
Re: Canvas, TBIII On Exterior Plywood
PostPosted: Tue Oct 28, 2014 7:18 am
by GPW
Dale , just use what you can get locally ...
... some glues dry darker than others ... TB2 dries amber , TB3 is Brown ...
PostPosted: Tue Oct 28, 2014 8:18 am
by dales133
Thanks once again.
I found a supplier of the foamular foam today*bonus.
Never ending research it seems!
PostPosted: Tue Oct 28, 2014 10:30 am
by GPW
Quote: “ Never ending research it seems!” ..... Seems like it eh ? :roll:
PostPosted: Mon Nov 03, 2014 11:45 pm
by andreuther
Canvas, TBIII on exterior plywood and then some paint? Thats my plan and i'm "sticking" to it. :beer:
PostPosted: Tue Nov 04, 2014 5:02 am
by GPW
Good plan !!! :thumbsup: ;)
PostPosted: Thu Apr 23, 2015 3:53 pm
by doris s.
Has anyone tried using Sunbrella material and then putting a clear coat of some kind over the material?
Maybe polyurethane?
Would it hold up like the canvas and exterior paint treatment?
Doris
PostPosted: Sat Apr 25, 2015 10:53 am
by rowerwet
It would depend on how paint stuck to sunbrella, really you should buy the cheaper fabric that matches the texture you want, the paint is the real protection.
Any fabric will fade in the sun, painted it cannot
PostPosted: Sun Apr 26, 2015 9:28 am
by Danidog
I wouldn't think paint would/could penetrate sunbrella like it can canvas?
Time to get back to work on my little trailer. I just ordered some canvas from the Internet that has no seams and is preshrunk. The canvas I purchased from the big box store last fall was full of seams.
PostPosted: Thu Apr 30, 2015 8:34 pm
by doris s.
I didn't think about the Sunbrella fabric repelling water/paint.
I could make a test board and see what happens.
Thanks for the info.
Doris
PostPosted: Wed May 06, 2015 9:22 am
by Gold5one
doris s. wrote:I didn't think about the Sunbrella fabric repelling water/paint.
Doris
Yes, I'm a big fan of doing test pieces- that's how I found out I could use CDX plywood on my walls. By accident I left a small piece of clear CDX in the backyard and picked it up a year later= no delams at all. The secret was finding CDX with very clear faces= takes time and a lot of sorting through bunks.
Waiting for a mockup test to yield results takes time and we know how short the building season is up north.
PostPosted: Thu Sep 10, 2015 9:05 am
by bradm
Great info in this thread! I'm still at the wall-building phase on my benroy right now, but starting to plan for covering.
Sam, I read your instructable and it's perfect. I'm going with canvas and TBII on my build. One question I haven't found an answer to yet...
When you are doing the glue -> canvas -> exterior paint process, are you throwing the first coat of paint onto the glue/canvas layer while it's still wet or waiting until that all sets up first then painting? My guess from prior painting projects would be that you let the glue and cloth set up and harden first then paint, but you mention impregnating the canvas, and I can't imagine that working well once the glue is cured.
Thanks for you instructable and to the whole community for an awesome forum.
Brad
PostPosted: Thu Sep 10, 2015 11:23 am
by desertmoose
The glue just holds the canvas to the wood. it doesn't fill or impregnate the weave of the canvas.
Roll/ brush the glue on, smooth the canvas on and let it dry. Trim overlap at edges, brush glue at the overlap and wrap canvas around edge. Let dry. Apply canvas on other side the same way, and you end up with a double layer of canvas at the edges.
After all canvas is applied, paint with thinned paint so it soaks into the canvas. then paint to the desired finish.
Actually real easy to do.
Sam
PostPosted: Thu Dec 17, 2015 1:50 pm
by vitya-velik
desertmoose wrote:We did our plywood with Titebond 2, canvas, and then exterior paint. Use the glue to fasten the canvas to the plywood. Roll it on, them smooth the canvas into place. Let it dry. You are now done with the Titebond. On top of the BARE canvas, put a coat of exterior house paint thinned about 50% so it soaks into the canvas. After that dries, use full strength paint until you get the look and coverage you want. Ours took 4 coats.
Titebond 2 works great. No need for the more expensive Titebond 3 since it is protected by the paint.
Others have used the Titebond on top of the canvas to try and cover the surface. But glue isn't made to cover, it sticks things together. Use it as intended and stick the canvas to the plywood. Then use the paint like it was intended, cover for waterproofing, appearance, and protection.
We used exterior latex. others have used exterior oil based. Our experience with the latex has been great. 2-1/2 years in the Nevada sun, snow, rain, and thousands of miles of towing. If I ever build another trailer, I WILL use the painted canvas covering.
Sam
What kind of canvas did you use?
PostPosted: Thu Dec 17, 2015 8:57 pm
by desertmoose
i used 10 oz canvas drop cloths from Harbor Freight. Cheap enough, especially with a coupon, but I did end up with a seam on the roof and sides since the drop cloths were sewn from small pieces. Look above the door and you can see one of the seams. We haven't had any trouble with having seams, other than appearance.
Sam
PostPosted: Sat Jan 02, 2016 12:15 pm
by Poorlytiedfly
We used exterior latex. others have used exterior oil based. Our experience with the latex has been great. 2-1/2 years in the Nevada sun, snow, rain, and thousands of miles of towing. If I ever build another trailer, I WILL use the painted canvas covering. :thumbsup:
Sam
Great post, thanks for the pics.
