Poly Over Exterior Semi-Trans. Stain?
Finishes, paints and coatings
Postby Danidog » Mon Nov 03, 2014 6:01 am
I have an oil based semi-transparent stain on my TTT siding. Would it be a good idea to seal that with maybe some Helmsman Spar poly for more protection? My paint store guy says "I dunno" :thinking:
thanks,
Dan
Danidog
Re: Poly Over Exterior Semi-Trans. Stain?
Postby 48Rob » Mon Nov 03, 2014 6:17 am
I use oil based poly over oil based stain all the time.
It has been done for years.
You can put oil, or water based finish over oil stain.
What you don't want to do is put oil over water based.
Oil dries hard and does not stretch.
Water based/latex stretches/moves, hard non stretch oil over soft stretchy latex will fail.
As to your question about "should I protect it" yes, it would be a good idea as stain does not seal the wood from moisture damage.
Rob
PS. You need to get a new paint store guy that has a clue.
Paint stores sell products that are designed to seal and protect multiple surfaces, inside and out.
If he can't answer that simple question, he isn't to be trusted to give advice on what kind of paint his customers need.
Visit Rob's World Web Page!
48Rob
Postby Danidog » Mon Nov 03, 2014 11:41 am
Thanks Rob.
This is the first BM paint store I've seen where the owner's family doesn't seem to care.
Danidog
Postby Tom Kurth » Mon Nov 03, 2014 6:09 pm
A long-time interior finish guy told me you could put poly a lot of stuff but make sure it doesn't have stearates in it. That's the stuff they add to sanding sealers so they don't gum up your sandpaper.
Best,
Tom Kurth
Postby mrwall1 » Mon Nov 03, 2014 7:00 pm
Poly would be a good choice... I am surprised B.M. didn't know.... they sell a really good Acrylic Poly... Benwood Stays Clear.....
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Return to Skinning secrets
