aluminum sides but not the roof
Finishes, paints and coatings
Postby Dalorin » Mon Jan 12, 2015 1:20 pm
All,
I have found a very reasonable source for 4 x 8 aluminum for the sides of my generic benroy build. However, getting the 5 wide aluminum for a roof is proving to be way more trouble than it's worth.
Is there some other material that is easily sourced in five wide that I can use for the roof and keep only the sides aluminum?
Thanks in advance
Dalorin
Re: aluminum sides but not the roof
Postby dales133 » Mon Jan 12, 2015 1:50 pm
I've had the same issue and have decided to use 4 foot sheets cut down to 5 across the width.
I didn't realy want joins but it was good enough for old vans and they didn't have polyurethane sealants so I'm pretty confident it will seal fune
dales133
Postby Dalorin » Mon Jan 12, 2015 5:32 pm
Yeah, I really do not want seams.
I found a truck parts place locally that will sell me some kind of frp off the roll in a 16 foot length.
They called it high gloss side liner. I believe it must be some other brand of material similar to filon.
I'm probably going to go this route
Dalorin
Postby wagondude » Tue Feb 17, 2015 10:15 pm
You could go with Marine vinyl. A couple of builds have gone that route ( Woodbutcher's Slow Mobile is one).
Bill
101137
wagondude
Images: 35
Postby alaska teardrop » Wed Feb 18, 2015 4:21 pm
Don't know where you're at, but really, 5' aluminum should not be that hard to find. Try the local industrial steel & metal supplier. It would be a shame to change your plans.
alaska teardrop
Images: 175
Return to Skinning secrets
