A new mill .025 aluminum product!
Finishes, paints and coatings
Postby MarcInBoise » Wed Feb 18, 2015 10:05 pm
interstate rv metals now carries a .025 mill finish aluminum.
Comes in 48" (any length) and 100" (any length).
Unfortunately they are a wholesaler, so I'm tying to find a local company that carries their products.
http://www.interstatervmetalandsupply.c ... u_dia2.htm
Re: A new mill .025 aluminum product!
Postby ae6black » Thu Feb 19, 2015 9:50 pm
I have to wonder if that thin would flap around in the wind while you're heading down the road. I wanted .04 but could only find .05 around the Pittsburgh area. Might be heavy but I've never seen it move in either heat or cold.
Images: 19
Postby Alan_H » Sat Apr 18, 2015 10:53 am
Any luck on finding a retailer?
Postby GuitarPhotog » Sat Apr 18, 2015 11:50 am
My all aluminum trailer is built from 0.050" aluminum over angle iron frame, and it's plenty sturdy and does not "oil can." If you are just skinning a wood trailer the 0.025" should be fine. If you're skinning, don't glue it to the underlying wood. Attach it at the edges with the trim only.
Images: 55
Postby Chilton82 » Fri May 29, 2015 3:48 pm
Did you end up using the .025? There's a place around here that has it for a reasonable price compared to the .050 in 5' that I need.
Return to Skinning secrets
