How to Attach Luan to Exterior Frame Prior to Aluminum
Finishes, paints and coatings
Postby MarcInBoise » Sun Mar 22, 2015 7:32 pm
Need to finish the wiring and it's time for the exterior/roof Luan, prior to installing the aluminum.
How is it attached? Wood glue? Gorilla glue? How is it held in place? Staples?
Will staples work themselves loose and push up against the aluminum making a dent from the inside?
MarcInBoise
Re: How to Attach Luan to Exterior Frame Prior to Aluminum
Postby tony.latham » Sun Mar 22, 2015 8:38 pm
MarcInBoise wrote:Need to finish the wiring and it's time for the exterior/roof Luan, prior to installing the aluminum.
Marc:
Sounds like you're chuggng away.
I use Loctite PL Premium poly* adhesive and 1/4" crown staples from a pneumatic gun. Works well. The crown stapes are set just below the wood, and then they get a covering of epoxy. I'm afraid that if bare steel got in contact with the aluminum, it'd start a corrosion spot.
T
* The big tubes are quite a bit cheaper per ounce.
Postby MarcInBoise » Sun Mar 22, 2015 9:20 pm
Thanks Tony, as always, I appreciate the input!
MarcInBoise
Return to Skinning secrets
