How to: Molding on a Floating Skin Install
Finishes, paints and coatings
Postby MarcInBoise » Thu Apr 30, 2015 6:59 pm
Okay the outer Luan is on, sealed and ready to be covered with aluminum.
I've rough-cut the aluminum, ready to route it down flush... doors have been done.
I've decided I'm going to float the aluminum instead of gluing. So is there anything applied under the edges of the aluminum like silicone to help keep water out, and is there anything that goes under the trim?
I've been reading/searching but haven't found an answer for this one.
I plan on putting screws in "wet"... install the screw, back it out, reinstall after putting sealant in the hole. Seems there has to be some kind of sealants under the molding itself.
MarcInBoise
Re: How to: Molding on a Floating Skin Install
Postby tony.latham » Thu Apr 30, 2015 9:10 pm
MarcInBoise wrote:Okay the outer Luan is on, sealed and ready to be covered with aluminum.
Marc: Nothing under the aluminum, but yes, absolutely a good sealant under the trim.
I install the trim without sealant, pull the screws, run a bead on the edge, and then reinstall it.
I've got a love/hate thing going with silicone but still use it. If you do, make sure you use GE Silicone II. The rest is corrosive. If you use the silicone clean it with acetone and then clean it four or five more times with acetone or it'll attract dust.
T
Postby H.A. » Thu Apr 30, 2015 9:42 pm
H.A.
Postby MarcInBoise » Thu Apr 30, 2015 10:18 pm
T
Once again Tony, I'm in your debt!
MarcInBoise
Postby halfdome, Danny » Thu Apr 30, 2015 10:51 pm
Try OSI QUAD.
In my opinion a far superior sealant than any silicone.
Comes clear and other colors.
Any sealant that oozes out from the trim can be peeled off in a couple weeks. :thumbsup:
:D Danny
halfdome, Danny
*Happy Camper
Images: 162
Postby Nobody » Fri May 01, 2015 9:04 am
halfdome, Danny wrote:Try OSI QUAD.
:D Danny
Danny, I value your expertise on most any construction advice. I 'googled' the OSI Quad & found different items from around $6 to over $70 for a 10oz tube :frightened: . Which one are you recommending? TIA...
Harvey -
Nobody
Images: 342
Postby Gunguy05 » Fri May 01, 2015 9:11 am
I used the grey version of this and it worked well. About 6 bucks at HD. http://m.homedepot.com/p/OSI-10-fl-oz-C ... /100173080
Brian
Checkout my buildThe Regal Eagle Bow front for 4
Also my teardrop updates from blog on Dad Rambles
Gunguy05
Images: 6
Postby halfdome, Danny » Fri May 01, 2015 10:07 am
:D Danny
The tubes in my link that cost around 6 bucks at Home Depot.
:D Danny
halfdome, Danny
*Happy Camper
Images: 162
Postby Nobody » Sat May 02, 2015 8:49 am
Thanks Danny, I'll give it a shot. I'm doing some sealing/caulking on a 2001 Casita Fiberglass trailer :thumbsup: Thanks also to Brian (GunGuy05)
Harvey -
Nobody
Images: 342
Postby dmdc411 » Sat May 02, 2015 12:07 pm
I too used OSI Quad. Hate silicone on anything outdoors. Quad just needs a good clean surface. It's messy, load it on so it squeezes out, let it set up, then clean up with a squeegee type tool by getting under it so you don't smear it. Then mineral spirits and a clean white rag. I went back after 2 weeks and did some more cleanup. It came right up with min spirits.
dmdc411
Postby MarcInBoise » Mon May 04, 2015 3:17 pm
dmdc411 wrote:I too used OSI Quad. Hate silicone on anything outdoors. Quad just needs a good clean surface. It's messy, load it on so it squeezes out, let it set up, then clean up with a squeegee type tool by getting under it so you don't smear it. Then mineral spirits and a clean white rag. I went back after 2 weeks and did some more cleanup. It came right up with min spirits.
Clean white rag? What Teardrop builder has a CLEAN white rag? :shock:
MarcInBoise
Postby dales133 » Mon May 04, 2015 4:31 pm
Turpentine works well for removing polyurethane adhesive as does paint thinners but the former is a safer bet on most surfaces
dales133
Postby skinnedknuckles » Wed May 20, 2015 6:45 am
I'm almost ready to skin my teardrop too :thumbsup: and I'm wondering how OSI Quad compares to Sikaflex ?
Paul
skinnedknuckles
Images: 21
Postby dales133 » Wed May 20, 2015 7:33 am
I'm only familiar with sikaflex and selleys armor flex but I'd highly recommend both.ive used several variants of sikaflex and it isn't cheap but I've used if for decades in construction without issue.the selleys is newer but comparable
dales133
Postby BigRedHiker » Fri May 29, 2015 3:59 am
My Advise...No Silicone anywhere. It eventually fails and nothing sticks to dry silicone well including silcone. Therefore it needs to be completely removed before a different sealant is used . There lies the problem..it is very difficult to get rid of it one you have applied it. RVs need routine maintenance which includes caulk sealant replacement over time. Sealants such as Sikaflex 221 can be peeled away and re caulked easily even though they last a long time..that is why its a better choice.
Silkaflex also makes caulking which is a structural adhesive..for bonding materials like aluminum. It has a low modulus and high elongation.
That aluminum wants to move with temperature change and if the adhesives cant move with it, they will eventually break bond.
Thats my 2 cents worth.
BigRedHiker
Images: 5
Return to Skinning secrets
