painting plywood
Finishes, paints and coatings
painting plywood
Postby glenn201 » Sun Apr 10, 2016 7:58 am
Whats the best way to paint plywood sides of my tear
glenn201
Re: painting plywood
Postby glenn201 » Sun Apr 10, 2016 6:04 pm
just need to know should i use oil base or latex
glenn201
Postby Art Mini » Mon Apr 11, 2016 7:33 pm
glenn201 wrote:just need to know should i use oil base or latex
I used an enamel primer/sealer. It takes a few coats to make sure it absorbs into the plywood. Now I can use a regular enamel house paint on it
HAVE FUN STORMING THE CASTLE!!!!
Art Mini
Images: 14
Postby Tomterrific » Tue Apr 12, 2016 9:09 am
I used oil based paint, primer and top coat. My thoughts were, it's water proof and that is how wood boats are painted. Now that a couple of years have gone by I might repaint with water based exterior paint.
Tomterrific
Postby GuitarPhotog » Tue Apr 12, 2016 8:20 pm
Tomterrific wrote:I used oil based paint, primer and top coat. My thoughts were, it's water proof and that is how wood boats are painted. Now that a couple of years have gone by I might repaint with water based exterior paint.
You might have trouble getting the latex paint to stick to the previous oil-based paint. My house was painted first with an oil-base paint, then some years later with latex exterior enamel. The latex paint did not bond to the previous paint at all. All but falls off the walls.
I think I would test using a primer over the current paint before painting w/ latex to see if that solves the problem.
<Chas>
:beer:
GuitarPhotog
Images: 55
Return to Skinning secrets
