List of places
Finishes, paints and coatings
List of places
Postby dogpound101 » Tue Apr 12, 2016 2:35 pm
Where to buy 5x10 aluminum near New Orleans
Doug
dogpound101
Re: List of places
Postby HarleyCamper » Tue Sep 06, 2016 4:14 pm
Look for Ryersons. They are all over the US.
Sent from my XT1080 using Tapatalk
HarleyCamper
Re: List of places
Postby Larry8 » Tue Sep 13, 2016 4:55 pm
Ryerson quoted me $135 for .040 5052 Al 60"x144"
My local metal yard could only supply 48"
Larry
Larry8
Images: 11
Re: List of places
Postby dmdc411 » Wed Sep 14, 2016 9:14 pm
I used .040 refrigeration aluminum. Think it's 5052, 4 x 8, and 4 x 10 on my 5'3"wX 10 TD. Have left overs that's all. Paid $46 for 8 ftrs, $65 for the 10ftrs.
dmdc411
Re: List of places
Postby dogpound101 » Thu Sep 15, 2016 6:03 am
[quote="dmdc411"]I used .040 refrigeration aluminum. Think it's 5052, 4 x 8, and 4 x 10 on my 5'3"wX 10 TD. Have left overs that's all. Paid $46 for 8 ftrs, $65 for the
Doug
dogpound101
Re: List of places
Postby dogpound101 » Thu Sep 15, 2016 6:04 am
dogpound101 wrote:
dmdc411 wrote:I used .040 refrigeration aluminum. Think it's 5052, 4 x 8, and 4 x 10 on my 5'3"wX 10 TD. Have left overs that's all. Paid $46 for 8 ftrs, $65 for the
How did you seam your roof?
Doug
dogpound101
Re: List of places
Postby dmdc411 » Thu Sep 15, 2016 1:27 pm
Flat RV trim. Lower sheet extends under the upper sheet, and the trim covers and keeps the seam tightImage
dmdc411
Re: List of places
Postby Tommy2tone_1999 » Wed Oct 19, 2016 12:33 pm
Denver Sign Supply Company in Slaughter, LA
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Re: List of places
Postby Andrew Herrick » Tue Oct 25, 2016 10:08 am
Not to hijack the thread, but just in case the original poster finds it useful:
I just tried something new (no pictures yet). I purchased some 1/8-inch aluminum pop rivets (0.063-0.125 grip range), overlapped my aluminum sheets 1.25 inches, drilled 1/8-inch holes 1.5 inches apart in the overlapping section, and pop-riveted the whole thing. It was much faster than seaming a roof with flat insert trim (which is also a pain if your joint lands on a curve).
Some notes:
The joint is strong, but not waterproof in itself. So I laid a bead of silicone II in the lap joint and tapped the underside with roofing repair tape. It looks really good! Really clean. And it costs less than aluminum trim.
You can buy a pop riveter for $20. But if you buy a cheap one, you should use aluminum rivets and not stainless steel. You'll break the riveter.
I think both ways look good and will hold up long-term.
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Images: 15
Return to Skinning secrets
