1"+ galley edge trim/molding
Finishes, paints and coatings
Postby MTalon » Fri Apr 29, 2016 2:48 pm
I can't seem to locate and galley edge trim that is over 1". My galley walls are just over 1" and I don't want to have a strange looking gap. I know Li'l Bear used to sell them but nobody else seems to. The HT10 from teardroptrailerparts MIGHT work but it has those ribs on it that I don't particularly like and the HT09 are too narrow.
MTalon
Images: 11
Re: 1"+ galley edge trim/molding
Postby TheOtherSean » Tue May 03, 2016 10:25 pm
Would regular aluminum stock (e.g. bar, angle, various extrusions) work well enough?
TheOtherSean
Images: 16
Postby MTalon » Fri May 06, 2016 1:40 pm
Maybe, but that trim has to be able to bend around a pretty tight radius as well as hold the side aluminum in place.
MTalon
Images: 11
Postby yrock87 » Mon May 16, 2016 8:58 am
I don't have an answer for you as I am facing the same problem. I have thought about overlapping trim from both inside and outside. I am thinking I my just use plywood and epoxy it to create a water tight edge for my walls. I will be subscribing to see what you come up with.
yrock87
Images: 97
Return to Skinning secrets
Users browsing this forum: Majestic-12 [Bot] and 1 guest
