CPES and Fill-It
Finishes, paints and coatings
CPES and Fill-It
Postby Specktre » Sun May 22, 2016 11:06 am
Good day,
I am about to sealed my wood but I dont know which step should be done first.
Should I use fill-it first and then CPES or it change nothing.
Thanks
Specktre
Re: CPES and Fill-It
Postby S. Heisley » Sun May 22, 2016 8:29 pm
Always use the CPES first. The CPES will penetrate the exposed top layer of wood. If you use Fill-it first, you won't have that advantage. Fill-it will not penetrate the wood; but, Fill-it is made to bond with the CPES.
Postby Specktre » Fri May 27, 2016 7:49 am
Thanks Sharon,
CPES done, i'll do the fill-it later :)
Specktre
Return to Skinning secrets
