haha49 wrote:I was wondering if I fiberglass will it eat the foam. I plan on using marine plywood routing it out stuffing foam on the inside then using carbon fiber for the skin. It would make the wall strong and light-weight so I was wondering if it would eat it. The other option is Kevlar if I want a cheaper material. I plan on using the pink insulation foam
OP827 wrote:If you are going to use expensive carbon or kevlar fabric for your trailer composite skin, the only logical choice is to use epoxy resin and as noted above, it will not eat this pink polyester foam.
If you still want to use cheaper polyester or vinylester resins then you could use polyiso foam (https://en.wikipedia.org/wiki/Polyisocyanurate) that will not be eaten by those resins. Use fiberglass cloth with such resins then.
