Hurricane hinge and skin caulk
Finishes, paints and coatings
Postby TallyTear » Wed Jan 11, 2017 8:46 pm
I believe most people use silicon on hurricane hinge. I am not a fan of silicon, thinking about using vulkem 116. Any opinions on running a bead of caulk under edges of roof and walls before installing roof edging with butyl tape? I was thinking about using the vulkem 116 also.
TallyTear
Re: Hurricane hinge and skin caulk
Postby aggie79 » Thu Jan 12, 2017 11:21 am
I'm not a fan of either silicone or butyl tape. Under my hurricane hinge and roof edge molding, I used 3m marine sealant. The Vulkem should work fine too.
For more on our Silver Beatle teardrop:
Images: 670
Postby TallyTear » Fri Jan 20, 2017 9:15 pm
I was thinking about butyl tape under flat area were screws go but also running a bead of caulk in the corner of roof edging trim. My roof metal is flush to wall but the wall metal is 1/8-1/4 short of being flush to roof. Any options? I would be using Vulkem 116. I also decided to use 3M 5200 under hinge.
TallyTear
Postby Tomterrific » Sat Jan 21, 2017 12:51 pm
I used rope caulk as a bedding compound under all metal parts. It's easy to use, lasts, easy to remove, self-healing. It works similar to modeling clay.
Tt
Tomterrific
Return to Skinning secrets
