Help me with walls and roof
Finishes, paints and coatings
Re: Help me with walls and roof
Postby QueticoBill » Tue Mar 07, 2017 10:37 am
Does anyone vacuum bag their wall panels, and maybe hatch lid? Roof/front wall seem hard as they always seem built in place. Is heavy polyethylene, tape or glued or rolled edge seams, and a shop vac silly? Looking for an inexpensive vacuum pump.
There is always tube sand......
QB
QueticoBill
Images: 22
Postby Andrew Herrick » Tue Mar 07, 2017 11:59 am
My knowledge of vacuum bagging is armchair only, but I've heard some people use a Venturi pump attachment with their air compressors to create an ad-hoc vacuum pump. Seems to work pretty well.
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Postby KCStudly » Tue Mar 07, 2017 2:24 pm
I did my inner wall skins with a shop vac, sheets of bubble wrap as a distribution media, sheet plastic and tape. Built my own adapter for the shop vac hose. It worked, but I think I could have gotten a better result using a proper vacuum pump with sufficient capacity.
Images: 8114
Postby Atomic77 » Tue Mar 07, 2017 5:06 pm
I used a shop vac as well. Just remember is not the "draw" that does the work. It's that the vacuum allows atmospheric pressure to become the clamp. My suggestion would be don't worry about the vac, but do use a thicker plastic that doesn't "stretch."
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 308
Return to Skinning secrets
