Skinning a 5x10x5 teardrop with 4x8 Luan
Finishes, paints and coatings
Postby El_Ducko » Wed Feb 08, 2017 12:36 am
How does everyone transition from one 4x8 sheet to another on the inside of their teardrop? I could not find 5ft wide luan. I like the wood look so I don't want to paint either.
El_Ducko
Re: Skinning a 5x10x5 teardrop with 4x8 Luan
Postby KennethW » Wed Feb 08, 2017 7:14 am
Glue 3" strips on the back side connecting the three 4x5 panels to made a 5x12 panel worked for me.
KennethW
Images: 82
Postby swoody126 » Wed Feb 08, 2017 7:19 am
might i suggest vertical battens on 16" or 24" centers, which would cover the seams
you can create them from contrasting or complimentary wood, finished naturally
some big box stores carry prefinished batten material in 8' lengths
or you can rip battens from the same material as the wall panel
OR you could rip them from the wall panel material and cover/wrap them with your accent/curtain fabric(s)
running vertical seams would increase your expense butt not by much(1 or 2 sheets maybe)
just an old man's 2¢ worth this morning
sw
swoody126
Postby rruff » Wed Feb 08, 2017 9:57 pm
What the other guys said. :thumbsup:
And if you want to get fancy you can make a scarf joint. Image
rruff
Postby wingloader » Tue Jul 04, 2017 5:29 pm
El_Ducko wrote:How does everyone transition from one 4x8 sheet to another on the inside of their teardrop? I could not find 5ft wide luan. I like the wood look so I don't want to paint either.
I originally skinned the outside of mine with 4 x 8 Luan. I have the same dimensions as you. It was hell bending that stuff. In my build journal/gallery I have some pictures showing what I had to do to join the two pieces and bend them around the curve. It was a nightmare.
107146 107145
After four years, the joints where the two pieces were joined started to pop open and it was ugly as hell. Also water started to get into the wood. I just got done tearing off the outer skin. I got something plywood from Home Depot to redo it and it bends so much easier than Luan. I'm still going to have the issue of trying to connect two pieces of plywood and have them bend around the curve without breaking apart or having a funny flat spot.
Now for the next problem. Where do you get 5 foot wide aluminum? If you want to skin the entire top with one un-seamed piece of aluminum, it's probably going to be hard to get. I haven't been able to find it yet. I am thinking about getting some kind of white vinyl that is 5 feet wide in a big roll that I can skin with. That would probably be a lot easier to work with.
I am really starting to wish I had just done mine 4 feet wide. It would've been so much easier.
It takes a big man to cry, and an even bigger man to laugh at that man.
--jack handy
wingloader
Images: 76
Postby tony.latham » Tue Jul 04, 2017 6:21 pm
I'd call a lumber yard, (not a box store) and see if they can't get you sheets of 5x5' 1/8" Baltic birch. Luan is a generic term for stuff that's meant for interior doors. I'm not impressed with it. Some of it is quite junky–especially the stuff Iv'e seen in Lowe's and Home Depot. Baltic birch is really great stuff.
For joining my ceilings, I butt the two pieces of BB ply and then glue a 4" strip over the seam using TB2. (Lots of weight on the strip while it glues.) When you install it, you should try and get the seam as close to a flat spot as possible. But it works great.
T
Postby wingloader » Tue Jul 04, 2017 6:22 pm
tony.latham wrote:I'd call a lumber yard, (not a box store) and see if they can't get you sheets of 5x5' 1/8" Baltic birch. Luan is a generic term for stuff that's meant for interior doors. I'm not impressed with it. Some of it is quite junky–especially the stuff Iv'e seen in Lowe's and Home Depot. Baltic birch is really great stuff.
T
Awesome. Thanks for the quick reply!
:beer:
--jack handy
wingloader
Images: 76
Postby wingloader » Mon Jul 10, 2017 1:10 pm
Got my 1/8 baltic birch on order! Unfortunately, my camper is 5 feet wide so to cover the 16 feet, I have to order 4 sheets! If it was only 4 feet wide, it would only need 2. Lots of scraps for sure. But hey, it's worth it. Plus, I think it will bend easier from the 4 foot side rather than the 8 foot side.
Hey...whatever it takes to have a sweet ass camper!
--jack handy
wingloader
Images: 76
Postby tony.latham » Mon Jul 10, 2017 3:24 pm
wingloader wrote:Got my 1/8 baltic birch on order! Unfortunately, my camper is 5 feet wide so to cover the 16 feet, I have to order 4 sheets! If it was only 4 feet wide, it would only need 2. Lots of scraps for sure. But hey, it's worth it. Plus, I think it will bend easier from the 4 foot side rather than the 8 foot side.
You'll love that stuff. But remember, it wants to bend one direction, and not so much the other.
How much a sheet?
T
Postby wingloader » Mon Jul 10, 2017 7:26 pm
tony.latham wrote:How much a sheet?
I didn't even ask. I don't want to know. :frightened:
just curious...does it bend easier lengthwise or width wise? I'm going to be cutting off 3 feet from each sheet and only getting 4 feet of coverage per sheet as I go up and around. (I have plans for the scraps so they aren't going to go to waste) I guess either way, it has to be easier to bend than the luan (underlayment) ply. As you can see by the pics above it was almost dangerous whilst bending it because the force needed was pretty hefty.
I did the inside (headliner) with the same material. It is also starting to bow out at the seam. I am going to have to put a 1" square steel tube as a spar to hold down the inner skin. There is only 1.25 inches of space for a spar and oak wouldn't even be strong enough to push down the bowing joint. Gawd. If I had 3 grand, I'd just start over. Knowing what I know now, it would be so much better.
--jack handy
wingloader
Images: 76
Postby pchast » Mon Jul 10, 2017 7:56 pm
It can actually be ordered/made to bend either way.
pchast
Images: 96
Postby wingloader » Tue Jul 11, 2017 7:54 am
Hey Tony, I found it is $15 per sheet so my fears have been vanquished. At that price, I'll join a couple pieces together.
It's been years since I was on this forum. It feels good to be back here with y'all!
--jack handy
wingloader
Images: 76
Postby tony.latham » Sat Jul 15, 2017 1:37 pm
Well.... the stuff I use comes in 5x5' sheets.... :thinking: It really wants to bend one way but not so much the other....
Postby wingloader » Mon Jul 17, 2017 9:54 am
YEA!!! My baltic birch came on Friday. It is 5 X 5!!!!!!!
I didn't know that all Baltic Birch plywood comes 5 x 5 :-)
This stuff bends so nicely, I was jumping up and down. I made my entire family come out and look at how easily I can bend it.
OMG. Thanks for the advice to get this plywood. FYI, it was $15 a sheet. That's half the cost of a piece of luan plywood in the box store.
--jack handy
wingloader
Images: 76
Postby pchast » Mon Jul 17, 2017 9:19 pm
pchast
Images: 96
Return to Skinning secrets
