Need aluminum source in Portland, Yakima area
Finishes, paints and coatings
Postby Graniterich » Tue May 02, 2017 9:31 am
Posted a few months ago, hopefully spring will help. Recently moved above the Columbia gorge and are building a home and shop to build some more teardrops. Anyone know of a source for 5052 sheets. I use to get pvc wrapped to avoid scratches, but I will take what I can get. Thanks for any help, our zip code is 98620
Regards Rich
Sent from my SM-G920V using Tapatalk
Graniterich
Re: Need aluminum source in Portland, Yakima area
Postby Louisd75 » Wed May 03, 2017 4:47 pm
I believe that the user Colemancooler is in Yakima. He's been responsive to PM's when I've had questions about his sources for materials.
Louisd75
Images: 85
Postby Graniterich » Thu May 04, 2017 8:29 am
Thanks much
Graniterich
Postby clear82star » Fri Dec 15, 2017 8:25 am
http://www.pacificmetal.com/contact/
2 in Washington and 2 in Oregon
clear82star
Postby Graniterich » Fri Dec 15, 2017 9:40 am
clear82star wrote:http://www.pacificmetal.com/contact/
Thank you very much
Sent from my A1-840FHD using Tapatalk
Graniterich
Return to Skinning secrets
