Help with sealing out the last of the leaks
Finishes, paints and coatings
Postby Evan Dunville » Tue Aug 15, 2017 10:11 am
I have taken my teardrop out for 2 trips and it currently lives outside on my parking pad exposed to the weather.
I have a few small areas that still have the potential to produce slight leaks.
-2 back corners where the framing and back of the trailer meet and water can potentially wick in from the floor.
-2 front corners with the same issue
I built frame and panel doors and in heavy rain water is able to go around the panel and leak inside.
I also want to add a gutter above each door frame. and angle the bottom of the door frame so any water that makes it that far will have a tendency to run back out.
These problems are all able to be fixed but I would not mind getting some opinions on how i plan to fix each.
The back corners and front corners I plan to seal using some kind of a silicone or similar product and i would greatly appreciate any suggestions to the product to choose. I want to fill the void so its water tight and i don't get contact between the wood and water.
for the doors i will add some small holes so water is able to drain away and not pool in the groove for the panels. I will also add some Lexel clear silicone on the inside to add to the protection. I also get some water wicking through the wood so adding finish to doors should help. I'm leaning towards something oil based that can be reapplied rather than a film finish.
I will be adding some pictures this evening to help show what i am referring to if its not clear.
Evan Dunville
Return to Skinning secrets
