Formica for interior?
Finishes, paints and coatings
Postby mtnwanderer » Sun Sep 10, 2017 9:23 am
I saw some awesome boomerang Formica used in the galley and it got me thinking that Formica would be a really easy material to skin the interior of the cabin. It also comes in a great variety of styles and designs. Any color me to skinning the interior in Formica? Cost seems a bit high depending....
mtnwanderer
Re: Formica for interior?
Postby Gold5one » Sat Sep 16, 2017 8:17 pm
Formica has little structural strength- that is why it's glued to plywood. So, if you have to skin the inside with paneling/Luan for a base to glue the Formica to, I wouldn't want to spend the money to cover it up with Formica.
Mark
Weekender-XL build journal
sold-2018
Gold5one
Images: 92
Postby MtnDon » Sat Sep 16, 2017 8:45 pm
Whatever pleases you. Could be attractive and more of a one of a kind look. Usually contact cement is used, that might tricky inside a TD. Use 3M NF30 as it is less odorous, non flammable and kills fewer brain cells.
MtnDon
Images: 24
Postby LMarsh » Fri Sep 22, 2017 11:27 am
That's what I used, it turned out awesome and is waterproof and durable. I used all over and will be making a table top too. See my build journal
Actually it looks like I need to go through and fix some links and post some new photos. I'll try to get more of the interior too.
LMarsh
Images: 187
Postby QueticoBill » Fri Sep 22, 2017 12:47 pm
I have used plastic laminate on foam for acoustical panels and it works fine except for dimensional stability. I believe across a sheet - there is a grain to it if you look at the rear face - it can vary 1/4" in 48", from 10% to 90% rh, or in that ballpark. What the panel fabricators found was that the aluminum edges had to be joined with rivets and slotted holes to allow for it to change size or else it would bubble as the frame restrained it.
QB
QueticoBill
Images: 22
Postby Aguyfromohio » Fri Sep 22, 2017 2:06 pm
We put it on the counter tops for our build and I've used it a lot around my house.
I love the material -exceptionally durable, warm to the touch,easy to work with.
Aguyfromohio
Images: 44
Return to Skinning secrets
