Thin galvanized sheeting for skin?
Finishes, paints and coatings
Postby MatBirch » Sat Mar 16, 2019 12:28 pm
Looking at some cool options and ideas as I get started on my trailer. My wife and I have always loved the distressed look of patina’d galvanized steel. In a quick search, it’s easy to find roof flashing in 20” width rolls. I could cover the joints with strips of just about anything. I was thinking of polished 1/8” aluminum, controlling the galvanic corrosion of dissimilar metals by installing them with VHB tape. I’d seal the butt joints in the sheeting first with p/u caulk.
We’d patina the galvi with mild acids, rust it up a little, and then clear coat it.
I’m only envisioning this on the top/front. Probably paint the sides in her favorite turquoise and brown combo. 8)
MatBirch
Re: Thin galvanized sheeting for skin?
Postby Bob Hammond » Mon Mar 18, 2019 3:49 pm
If you want nearly 'invisible' seams, you could seal the joints from the inside with 3M VHB (Very High Bonding) tape or another brand that is used for trailer skylights. The 3M products have withstood 10 years total immersion in water.
Curator
Museum of Unfinished Projects
Bob Hammond
Postby KTM_Guy » Wed Mar 20, 2019 8:09 am
You should be able to find 4X8 sheets of 32 gauge galvanized sheets at any HVAC supply house. If you live in a bigger metro area 5X10's shouldn't be a problem.
One of the metal supply stores by me has a display for their acid etch and dyes for metal and the turquoise one jumps out at me. I like it a lot, some day I will have time to mess with some to see how it works. Not sure I would want a distressed camper unless I was pulling it with a "Rat Ride" But that's just me.
Corten might be an option if you want rusty. That is a big look that I like in the South West.
Todd
KTM_Guy
Images: 193
Postby twisted lines » Wed Mar 20, 2019 3:37 pm
Todd
Sounds like Steel FX ; dies & patinas! He does make some nice stuff and videos.
Racking up; And Rapin foam
twisted lines
Postby bdosborn » Wed Mar 20, 2019 5:04 pm
How about galvanized roofing sheets?
Images: 772
Postby EOCharley » Sat Mar 07, 2020 5:49 pm
I am currently building an expedition trailer using flat "coil" sheets of 26 ga (0.48mm) metal roofing as skin material over a box built of 3/4 inch plywood. The sheets come 41.5 inches wide by 10 feet long. They are coated with Ceramastar 1050 which is an SMP (silicone modified polyester) coating. Tough stuff to say the least. $38 per sheet was a great buy! I haven't posted my build here because i didn't see where it would fit but one could find it on expedition portal.
EOCharley
Postby twisted lines » Sat Mar 07, 2020 6:52 pm
EOCharley wrote:I am currently building an expedition trailer using flat "coil" sheets of 26 ga (0.48mm) metal roofing as skin material over a box built of 3/4 inch plywood. The sheets come 41.5 inches wide by 10 feet long. They are coated with Ceramastar 1050 which is an SMP (silicone modified polyester) coating. Tough stuff to say the least. $38 per sheet was a great buy! I haven't posted my build here because i didn't see where it would fit but one could find it on expedition portal.
So make one! if they don't like it they will ban you :pictures: :)
twisted lines
Postby tony.latham » Sat Mar 07, 2020 10:17 pm
I don't see it there. I tried a search using "Ceramastar" and drew a blank.
:thinking:
Postby EOCharley » Sun Mar 08, 2020 6:10 am
For those wishing to follow my build on the Expedition Portal site follow this link-
https://expeditionportal.com/forum/thre ... ld.207654/
EOCharley
Return to Skinning secrets
