thoughts?
Finishes, paints and coatings
thoughts?
Postby Wellcraft290 » Wed Feb 05, 2020 12:15 pm
So thinking
Plywood then fiberglass then fiberglass primer then topside paint.
Looks like will be a nice finish with proper prep etc. UV protectant as well. thoughts?
Wellcraft290
Re: thoughts?
Postby Philip » Thu Feb 06, 2020 9:33 am
If you look at the build with the link in my signature. That is what I did. Fiberglass, high build boat primer and topside paint.
The only issues I had was that topside paint needed waxed about once a month . If you didn't the paint would go dull and fade.
Philip
Images: 323
Re: thoughts?
Postby Wellcraft290 » Mon Feb 10, 2020 12:55 pm
Looks good. You did pick a tough color too. I chose battleship grey. will spray on and seems to be a lot of online reviews for people using on their boats and all very happy. plus the price. I mean 6 quarts for 50 bucks. TY amazon and their mistake
Wellcraft290
Re: thoughts?
Postby Philip » Tue Feb 11, 2020 9:15 am
I brushed on. It flowed real nice. I used about 1.5 quarts for everything I painted. I could have sprayed. I didn't want to deal with all the covering the inside of the garage to do that.
Philip
Images: 323
Re: thoughts?
Postby Wellcraft290 » Tue Feb 11, 2020 9:36 am
it does look nice. Black always looks great.
brush or roller? sand between coats.
I bought 6 quarts. amazon mismarked the price got for 7 bucks a quart lol
Wellcraft290
Re: thoughts?
Postby Philip » Tue Feb 11, 2020 12:44 pm
Read the can if you go to roll it on. The stuff I used said 1/4" nap on rollers. Going local I couldn't find one that short on the nap. I used 3/8" nap worked good. Did have lint problems on the first wall.
Did not have to do a second top coat. One coat was enough. I did sand the high build primer. Used 200 grit on it. That was the highest count paper I had for a 6" D/A.
Philip
Images: 323
Re: thoughts?
Postby Wellcraft290 » Tue Feb 11, 2020 1:50 pm
thank you. yeah heard foam or low nap. thinking easier to just spray on a very non windy day
Wellcraft290
Return to Skinning secrets
Users browsing this forum: jasonj and 2 guests
