* Here's a quick checklist to help anyone decide if they should look into Weight Distributing Hitches and Sway Control
- reasons to install a Weight Distribution Hitch system.JPG (47.45 KiB) Viewed 5986 times
* I've used both on many trailers over the years, and I always have them standing-by, if I even only tow a short distance, just in case. I've had overloaded trailers, improperly loaded trailers (loaded that way by necessity, not by choice: too light on the tongue or too heavy on the rear), and with trailer axle too far forward, and/or the ball-coupler too high in relation to the trailer rear, or tow vehicle too light compared to the trailer load. In any or all of those situations, I was able to tow successfully, without sway, due to using WDH and Sway Control.
* My old open race-car trailer was first towed by me using a lightweight (compared to today's trucks) '69 Chevy C-10 pickup, that weighed in at 4200 lbs fully loaded. At the same time, my trailer weighed in at 4400 lbs, with Chevelle on board. Many times on my first two long-distance racing excursions, I experienced some white-knuckle driving, when the trailer wanted to take control. I went to a swap meet, and found a complete WDH set-up for $100 (with mixed manufacturer's parts assembled). After that, I've never had a problem, though my next two trucks weighed more and more ("75 C-10 = 5000 lbs with more equipment on board, then the '04 Chevy 2500HD, with 1500+ lbs of equipment onboard, = up to 6900 lbs).
The suspensions, transmissions, and engines were modified on all three, to cope with large load-outs & high speed travel..
* Though I never anticipated that my TTT would need the WDH, three reasons compelled me to adapt it to use the WDH: 1) trailer was way too high (at first) on the nose (truck too tall, trailer too low), 2) axle was too far forward, at 55/45 ratio, until I compensated for it by shifting more weight forward, and 3) the TTT's weight initially was centered to the rear of the axle. So, I used the WDH (no sway control needed) for 6.5 years, until I had corrected all the problems. Nevertheless, I still hook up the WDH if travelling over 250 miles, or I anticipate bad roads or road conditions. Better safely under control, than the other way around.
* About jacks: I have a jockey-wheel jack and a scissor jack both mounted on the TTT's tongue (I need both types when maneuvering my trailer backwards into the garage), two pipe-clamp stabilizers on the rear corners (just stabilizers, not lifting type), and carry three bottle jacks, a trolley jack, a bumper jack, and a High Lift farm jack in my truck, for any emergency usage on the road. I also have a bad back, but you have to do what you have to do, when travelling solo !
