Trailer brake controller ... which one are you using
Postby Vspec » Wed Apr 19, 2017 9:48 am
Leaning toward a digital one vs analog. My TV, 2017 Pathfinder, already has a pig tail connection under the dash and a 7-pin at the rear.
Recommendations? Which one to stay away from? Bad experience, good experience?
Vspec
Re: Trailer brake controller ... which one are you using
Postby working on it » Wed Apr 19, 2017 11:42 am
  • I've used time delay braking controllers on all my trucks and on other vehicles I've put them in. My preferred controller is the Hopkins' Impulse, which I installed in my '04 Chevy Silverado, and in my Father-in-laws '03, and in 5 others, all Chevrolet, using the plug'n-play wiring they came with. I put one to the left underside of the dashboard (for a left-handed friend), and the remainder to the right. I angled all of them slightly upwards, and some closer to the driver, per their choice. All have functioned well, for many years (12-13 years, since installed).
  • For other trucks, which I had done before I got the Impulse, I used a Reese Brakeman, also a time delay controller, which I installed on two of my old trucks (and also on my wife's GMC, when I had to replace her failed Tekonsha, and that was the only one I could get immediately-she was leaving in an hour, on a rush insurance call-). They were not plug'n-play, but easy enough to wire up. Both brands of controllers could have been mounted at any angle, but I've found that the "underdash/beside the steering wheel" position has been universally liked by me and others.
    Hopkins' Impulse (like mine).PNG (167.93 KiB) Viewed 1795 times
    my go-to brake controller
    Reese Brakeman.PNG (108.38 KiB) Viewed 1795 times
    my old favorite controller, cheaper but reliable
    brake controller preferred mounting position.jpg (94.4 KiB) Viewed 1795 times
    easy to see & reach, out of the way install sites
2013 HHRv "squareback/squaredrop", semi-offroad, 4x8 TTT, 2065 lbs
  • *3500 lb Dexter EZ-Lube axle, w/brakes, 3000 lb. springs, & active-progressive bumpstops
  • *27x8.5-14LT all-terrain tires (x 3) *modified Weight Distribution system for single-beam tongue
  • *LED lighting, triple fans, Pioneer stereo *A/C & 110vac heat, Optima AGM, inverter & charger(s)
  • *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill
  • *zinc/stainless steel front racks *96"L x 6"Dia. rooftop fishing rod/reel carrier
156212148599156215
working on it
Images: 449
Postby dancam » Wed Apr 19, 2017 1:17 pm
working on it wrote:[list][*]I've used timed controllers on all my trucks and on other vehicles I've put them in.
Why always times ones?
dancam
Postby working on it » Wed Apr 19, 2017 2:20 pm
dancam wrote:Why always times ones?
  • Huh? I don't understand what you're referring to. If you're asking if I use just onecontroller per vehicle, yes, of course, those "time delay" controllers are good for one or two axles, which covers all my trailers.
  • Note that I corrected the "timed" to "time delay" description of the controllers, in my post above. It more accurately describes the simple braking action that the controllers exert, a delay before ramping up to the chosen power level. Proportional braking controllers use inertial sensors, and sense and adjust braking power to fit the situation. I've gone "old school" by choosing what I know and trust, the "time delay" kind, where I can choose how much braking I want to use (it can come in handy in slow moving, stop and go traffic, using just manual trailer braking, rather than the truck brakes).
    time delay braking controllers.PNG (9.09 KiB) Viewed 1767 times
    description of time delay function
    Proportional brake controllers.PNG (10.49 KiB) Viewed 1767 times
    description of proportional function
  • Sure, I've locked up my single-axle brakes, when I pulled into a service station after highway travel (I forgot to set the braking percentage to less-aways had controllers on tandem axles before, not a lightweight single axle). You do have to adjust the percentage for varying speeds, loads, and conditions. I was just using trailer brakes on my TTT for the first trip; I wasn't used to it, yet. Though my TTT isn't lightweight anymore (now at 2000 lbs), my truck doesn't really need the trailer brakes to stop it.
  • Choosing the type of controller is up to the user: I chose the time delay. It's what I've always used, and trusted, and can mount anywhere, at any angle, if I choose. Proportional is probably a better choice for light trailers, inexperienced users, varying road conditions; but, they're more expensive, and I think they have to be mounted level (so the motion sensor will function).
156212148599156215
working on it
Images: 449
Postby dancam » Wed Apr 19, 2017 3:00 pm
^i meant time delay vs. Pendulum controllers, i thought maybe you had used an inertia one and didnt like it.
I have never used a time delay one, the inertia idea just seems better to me and i didnt think the inertia ones are too expensive.
Inertia ones can be mounted at varying angles, you just move the pendulum reference point with a lever on the side of the controller.
Inertia ones are affected by weather your on flat ground, going uphill or downhill but it usually works in your favor. They brake less uphill and more downhill. But thats kinda what you want.
dancam
Postby Shadow Catcher » Wed Apr 19, 2017 6:57 pm
We have a Tekonsha Prodigy P2 Trailer Brake Controller which is Proportional. We have not had a problem and it works as it should.
http://www.tekonsha.com/products/brake-controllers/proportional-controllers/trailer-brake-control-proportional/TzaIxkVx1cI5XOy!osRB52uqDvaehMa!
Images: 200
Postby capnTelescope » Thu May 25, 2017 11:32 pm
I use a Tekonsha P3 controller.
I wrote a Howto based on my install. YMMV.
Brad
My Build
capnTelescope
Images: 365
Postby DIY_Stu » Sat Oct 21, 2017 9:28 am
I bought and installed the Tekonsha P3 after reading many many many reviews. Just came down to Cost of truck, Cost of trailer, and possible medical expenses. Why not get what is rated as the best?
DIY_Stu
Postby troubleScottie » Sat Oct 21, 2017 11:54 am
The electronic proportional brake controllers need to detect the change of inertia of the vehicle.
Originally the detection used a mechanical pendulum. So the controller had to be level. If it was not, the detection was off. Similarly if the vehicle was climbing or descending a hill, this also affected the braking.
Newer system use electronic inertia detectors which do not care how they are oriented or whether the vehicles are descending or ascending. They do need to be aligned with the path of motion ie point forward.
The timed systems were most likely more consistent than the mechanical pendulum system. The newer systems are better than the timed ones.
A question to those who might know, do any of the controllers get triggered by the vertical motion like a really bumpy road surface.
Michael Krolewski
Scottish Terrier Fancier
troubleScottie
Images: 10
Postby bdosborn » Sat Oct 21, 2017 2:36 pm
I also use a Tekonsha:
Tekonsha P3 Linky
I like the P3, it has on-board diagnostics that work well. It's also easy to move from one vehicle to another.
Images: 452
Postby capnTelescope » Wed Nov 08, 2017 1:02 am
troubleScottie wrote:A question to those who might know, do any of the controllers get triggered by the vertical motion like a really bumpy road surface.
On my summer road trip to Alaska this year, I drove many bumpy and/or unpaved roads without a hiccup from my Tekonsha. I would consider that trip to be a pretty thorough test.
Brad
My Build
capnTelescope
Images: 365
Postby Andrew Herrick » Wed Nov 08, 2017 8:23 pm
Thanks to everyone for sharing their experiences. Learned a lot. This article from etrailer helped me learn about the basics. Here it is as reference: https://www.etrailer.com/faq-brakecontroller.aspx
Has anyone found that wireless controllers are worth the extra cost?
A few of my builds:
Andrew Herrick
Images: 15
Postby Aguyfromohio » Thu Nov 09, 2017 1:36 pm
Has anyone here used a brake controller like this one? It's Hopkins InSIGHT Flex-Mount Trailer Brake Controler.
The more popular controllers like Tekonsha Prodigy P3 require the box to be mounted level in one axis.
The interiors of newer vehicles are sculpted pretty curved, making it hard to find a good mounting location at all.
This one puts the accelerometer in any remote hidden location.
The controls and displays get mounted wherever they are convenient without any need to have them level.
It seems like a nicer installation.
https://www.etrailer.com/Brake-Controll ... 47297.html
Aguyfromohio
Images: 44
Postby nemoskull » Mon Oct 01, 2018 5:24 pm
im using one a built. an arduino with a mosfet and a sensor on the brake pedal. works good.
nemoskull
