Trailer Lights Problem
All about towing and tow vehicles
Postby djohnsonnv » Tue May 23, 2017 9:44 am
The other week I set up my Kia Soul for light towing. I purchased a Draw Tight Class I hitch and a Curt T-Connector Wiring Harness from E-Trailer. The set up is pretty straight forward. Plug in a t-connector in each taillight and ground the system to the vehicle with a self tapping screw provided. Install went well but when I plugged in the trailer I ran into a problem.
The trailer lights will only run if the vehicle's taillights are unplugged. I contacted etrailer and did some research online. NOt too much on the subject since the Soul isn't rated for towing in the US.
My theory is that it isn't grounding well and/or the load is too high to run both the vehicle lights and the trailer lights. My question to the forum is would stripping the paint between the grounding wire and frame help? Does this theory make since? Has anyone ran into a similar issue especially with the type of wire set up?
djohnsonnv
Re: Trailer Lights Problem
Postby friz » Tue May 23, 2017 10:25 am
I would contact Curt. Your harness should be vehicle specific. I noticed that they offer two models. One if you have led tail lights on your car and a different one for conventional tail lights.
The "Sin Bin"
150133
friz
Postby tony.latham » Tue May 23, 2017 10:56 am
Friz has a good point so that may be it.
The preponderance of trailer light problems stems from the ground. Yes, I'd try scraping off the paint and adding a coat of dielectric grease to prevent corrosion.
Postby Norm » Tue May 23, 2017 8:27 pm
Installed plug in connector on my 2011 Soul. Mine feeds load directly from battery. I have no problems so far.
Norm
Images: 10
Postby Dale M. » Wed May 24, 2017 7:51 am
Paint should always be removed under any ground connection... And yes a dab of dielectric grease (light bulb grease) to keep moisture and oxygen out of "connection" is desirable...
Dale
Dale M.
Images: 18
Return to Towing and Tow Vehicles
