Comet design? Anyone have/use?
This includes traditional teardrop shapes and styles
Postby Eric Adams » Tue Sep 21, 2004 10:56 pm
Wondered if anyone has made the "Comet"? The larger version of the "Cub"
Eric Adams
Postby mexican tear » Wed Sep 22, 2004 8:48 am
Eric
My TD is a comet, sort of. I used all I could and then wandered off. I like the size and the shape. Oh yes I made it 5' wide too.
The plans realy give you a big help and answer lots of questions.
kai
"Essie" and the Mexican Tear
mexican tear
Images: 14
Postby Eric Adams » Wed Sep 22, 2004 9:54 pm
I wonder if anyone makes a full-size template for the Comet?
Eric Adams
Postby doug hodder » Wed Apr 13, 2005 11:20 pm
I'm currently building the Comet. I sort of did things the way I wanted, moved axle, built frame a little differently. My profile is the same however. Woody sides, gonna be aluminum skin top. Check out my album on this site for pics....Doug Hodder
Postby rjhager » Thu Apr 14, 2005 9:11 am
Eric,
I'm in the process of building a Comet pretty much as the plans call for. I did extend the inside length to 80" but everything else is the same. You really don't need a template. It only takes about 10 minutes with a ruler (yard stick) and square and a 4-ft long dowel to lay out the entire profile. Kevin's plans (KuffelCreek) are really all you need but Andrew's site also has the layout available. Really, it's a *lot* easier than you'd think! 8)
Working on a KuffelCreek Comet.
rjhager
Postby Freedom II » Fri Jun 17, 2005 8:33 pm
I just ordered Kevin's Comet CD-ROM, so I am looking forward to the build. To be honest even though its been less than a month that I even knew TD's exsisted. I really like the size of a Comet compared to some other models.
Morgan
If you can read this, thank a teacher.... If you are reading it in English thank a veteran.
Freedom II
Return to Traditional Designs
