Check out this chassis:
http://tinyurl.com/alumchassis
That's a lot of weight savings over an all steel, 2" square tubing chassis!
Prem
madjack wrote:...nice looking frame...however, it is listed at 350#, about what my all steel frame weighs(my 5x9x14 Vs their 6x10x14)...not much of a weight savings there..also the 2200# rated axle is a bit of overkill for most tears unless you are planning to build a heavyweight...............
Steve_Cox wrote:madjack wrote:...nice looking frame...however, it is listed at 350#, about what my all steel frame weighs(my 5x9x14 Vs their 6x10x14)...not much of a weight savings there..also the 2200# rated axle is a bit of overkill for most tears unless you are planning to build a heavyweight...............
Geez,
I was going to say the same thing..... Of course there is always the "coolness factor" to consider
...I have been using 1x2x3/16th "C" channel for the frame...
