PVC Pipe as a tank
Re: PVC Pipe as a tank
Postby Doubltap » Sun Mar 17, 2013 6:36 am
Error in table. I believe the 3" pipe would give you 3.06 pounds for the .367 gallons of water, NOT 23.06 as is represented in the table. Jes my 2 cents!
Doubltap
When your outgo is more than your income, your upkeep will be your downfall !
Doubltap
Images: 181
Postby Henry Benner » Thu Mar 21, 2013 7:23 pm
How about just using a coil of 3/4" plastic pipe. Could be coiled in the trailer frame cavity, in a wall cavity, around the inside perimeter, etc.
Would be easy to have a number of coils joined together.
Henry Benner
Images: 10
Postby Bogo » Thu Mar 21, 2013 10:02 pm
Weight for volume. That's allot of wall volume for the water amount stored.
Bogo
Images: 39
Postby KBS » Mon Jun 03, 2013 10:24 pm
One cubic foot = 7.48 gallons.
Karl Stevens
KBS
Postby musjakey » Mon Jan 02, 2017 1:14 am
Soda kegs! Genius! I'm a home brewer so I have a few extra. I bet I could modify the pickup-tube so they would work on their side. They are stainless steel so they would be nice and tough. Has anyone tried this? Sorry to hijack the thread!
-Jacob
musjakey
Postby GuitarPhotog » Mon Jan 02, 2017 2:02 pm
musjakey wrote:Soda kegs! Genius! I'm a home brewer so I have a few extra. I bet I could modify the pickup-tube so they would work on their side. They are stainless steel so they would be nice and tough. Has anyone tried this? Sorry to hijack the thread!
-Jacob
If you have room for corny kegs of water, why not carry homebrew? Just kidding. Since corny kegs have such a large opening, you would have to drag them out to fill and then put them back in. And remember they weigh 5-8 lbs empty, more than plastic jugs.
Oh, and how would you pressurize it to get the water out? A CO2 tank adds to the weight and complexity.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Bogo » Mon Jan 02, 2017 7:03 pm
And what happens when you use CO2 to pressurize a water tank? I mentioned it before.
You could still fill them from an external water supply if you plumbed them right, but that could be tricky.
Bogo
Images: 39
Postby GuitarPhotog » Mon Jan 02, 2017 7:13 pm
Bogo wrote:And what happens when you use CO2 to pressurize a water tank? I mentioned it before.
You get fizzy water! And it doesn't taste good.
GuitarPhotog
Images: 55
Postby musjakey » Sun Jan 15, 2017 1:05 am
Great points! I decided on a normal 10 gal Roto-molded tank. The kegs would be durable but not worth the headache.
musjakey
Postby steinbachbyuma » Sun Jun 04, 2017 7:19 am
pappaw wrote:Does anyone know the formula to calculate a size pipe by the length to get the gallons it would hold? :thinking:
Diameter (in Feet so 12" =1 or 6" =0.5)
Diameter * Diameter *0.785 *7.48 = gallons of water per foot of pipe
steinbachbyuma
Postby cajundood » Tue Sep 12, 2017 8:56 pm
I saw a nice design somewhere on here. They used a 4" pipe capped at both ends....which was about 6 foot long. It was painted black and mounted on the roof. During the day the sun heats the black pipe and the water within. it wasn't much about 4 1/2 gallons or so, but it could certainly be used to either wash a few dishes or maybe even a quick shower. The little outdoor shower that i am brainstorming would make perfect use of the pvc tank. I'm gonna bend a piece of PEX in a u shape which will mount to the outside wall by the entry door....and hold a shower curtain. Since this tank would be roof mounted, there would be no need for a pump.....it'd basically be gravity fed, so there won't be very much pressure. Can then reach the little hand sprayer used in my kitchen sink to take a quick shower. :thinking:
cajundood
Users browsing this forum: KTM_Guy and 0 guests
