My build of Benroy Style Trailer
Re: My build of Benroy Style Trailer
Postby AlgoDan » Tue Mar 26, 2013 3:32 pm
Ok let me go check and see if its still on the piece.....
biziedizie wrote:Yup that would be the stuff :)
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby AlgoDan » Tue Mar 26, 2013 3:40 pm
Ok biziedizie here is what I got for you
biziedizie wrote:K thanks :)
103660
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Tue Mar 26, 2013 3:52 pm
Great, keep me posted as to what your doing with it lol.. :thumbsup:
biziedizie wrote:Thanks :) I just ran the # through the phone and they do stock it :)
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Tue Mar 26, 2013 7:44 pm
Ok, today I got the aluminum trim and formed, then fitted for the hatch....
103659
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Wed Mar 27, 2013 5:03 am
So today/tomorrow I plan on hanging cabinet doors, now that they have been stained and clear coated. I also need to run wiring harness through the frame. Then arrange to get the clear aluminum end caps powder coated..and to pick up the tires and fenders. Its coming down to crunch time so a lot of little things to do.....
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Wed Mar 27, 2013 12:44 pm
Ok got the wiring harness and the checker plate today. I need to finalize the dimensions for the tongue length, then get it welded up. I pre-drilled holes for side marker lights, and did the access holes to run wiring inside the frame. Also cut some more trim for the hatch....the list goes on and on but I see light at the end lol...
103712
103711
Build Journal
AlgoDan
Images: 238
Postby KCStudly » Wed Mar 27, 2013 3:40 pm
Looks good.
One good trick I read here somewhere on hanging cabinet doors is to clamp a temporary ledger up to the bottom of your cabinet frames and set the doors on that while screwing the hinges in. Gets them all perfectly level and straight to each other.
It is amazing how even just a little offset or tilt can be picked up by the eye when looking at straight lines. I haven't tried this trick, but it sure sounds like a good one to me.
Postby AlgoDan » Wed Mar 27, 2013 3:58 pm
I hear ya, thats why I went with a offset hinge on both the door and cabinet. Its pretty well fool proof. Thanks for the heads up.
KCStudly wrote:Looks good.
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Fri Mar 29, 2013 1:04 pm
Ok today a bit of everything, finish trimming edge of Galley door. Just need to form a drip rail mldg. at the roof and checker plate joint.
103795
Build Journal
AlgoDan
Images: 238
Postby S. Heisley » Fri Mar 29, 2013 2:22 pm
It looks like you might even be ahead of your schedule to be done by this coming May.
That aluminum chassis looks like a beauty, by the way.
You're doing a good job on your Benroy.
Don't forget to treat us to photos of your maiden voyage! We'll be watching! :thumbsup: :applause:
Postby AlgoDan » Fri Mar 29, 2013 2:27 pm
Thanks for the confidence booster...I plan by Aprils end to be out for a shake down. I will post maiden pics for sure.... Cheers :thumbsup:
S. Heisley wrote:It looks like you might even be ahead of your schedule to be done by this coming May.
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Fri Mar 29, 2013 2:33 pm
Ok cabinet doors hung with all hardware, scratch that off the list....also the panel below the cabinets is a pass through door to the galley. It will get a finish stain and sealer next.
103796
103794
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Fri Mar 29, 2013 4:07 pm
Now with most of the interior done, need to finish off connecting the control panel up. I have 7 runs of 12volt to wire up 2-12volt outlets and 1-12volt usb power outlet and 4 lights. Then do the 110volt power inlet, 3-110volt outlet GFCI one inside the galley and cabin and outdoor one.
103797
Build Journal
AlgoDan
Images: 238
Postby KCStudly » Fri Mar 29, 2013 8:52 pm
Cranking right along, and looking good doing it! :thumbsup:
Postby AlgoDan » Sat Mar 30, 2013 5:16 am
Thanks KC, Knowing that spring is here, with sunshine and warmer days. I need to get it done, itching for the campfire... :beer:
KCStudly wrote:Cranking right along, and looking good doing it! :thumbsup:
Build Journal
AlgoDan
Images: 238
