jjvw wrote:It doesn't lose pressure, it just doesn't build up very much as you pump. It never pumps up to where it is hard to pump like my other stoves. Stove works but doesn't last long before it need a pump up, even on one burner. It been that why since it was new, even after a new pump shaft and rubber. If you open cap after pump, you can hear the pressure release but not as much as it should.
