so i need a sink (updated, now i need a pump)
Re: so i need a sink
Postby milliejohn » Tue May 28, 2013 12:45 am
I like 5 gallon buckets, camp stools, camp sinks, coolers, storage, color code your gear, cheap, tough, you can even wash your clothes in one.
http://fivegallonideas.com/5-gallon-bucket-dimensions/ :designing:
Image ~I started out with nothing and I still have most of it left~
milliejohn
Images: 87
Postby Fyddler » Tue May 28, 2013 9:11 am
I picked up this little stainless bathroom sink for my trailer for $5.00. It's small, but I just plan on putting a blue water jug above it and use it for washing hands/brushing teeth. It will just drain into a bucket. For washing dishes I use a couple of pink hospital tubs.
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
Postby bobhenry » Tue May 28, 2013 11:48 am
here is my wash and rinse sinks. :D
The ball is two nested mixing bowls that serve as wash and rinse sinks.
Images: 2617
Postby Fyddler » Tue May 28, 2013 5:11 pm
Most of the time I just throw my dishes in the camp fire!
Fyddler
Postby Lonnie Mac » Tue May 28, 2013 5:23 pm
Still working out my build myself. I really thought I wanted a sink in the design, but after much thought, I will not have one. I would rather have all the space. In the meantime, we have been using this thing. It works GREAT! I laugh every time we do the few dishes we have to do after meals, and it will fit in my drawer after I am done with the build.
I think it was one of the best 40 bucks I have spent to date.
http://www.amazon.com/Coleman-2000006858-All-In-One-Portable-Sink/dp/B0042BZGV6/ref=sr_1_1?ie=UTF8&qid=1369779740&sr=8-1&keywords=coleman+portable+sink
Lonnie Mac!
AleNuts Radio and home of Brutus "Ten"!
President of the Brutus Ten Cult...
Build Thread (Almost): http://www.tnttt.com/viewtopic.php?f=50&t=53596
Lonnie Mac
Re: so i need a sink (updated, now i need a pump)
Postby Lunchbox7985 » Wed May 29, 2013 8:33 pm
so i found this faucet at menards
http://www.menards.com/main/kitchen/hot-water-dispensers/plumbworks-chrome-one-handle-drinking-water-faucet/p-1390306-c-8677.htm
so i can officially use this sink
http://www.menards.com/main/kitchen/kitchen-sinks/stainless-steel-bar-sink/p-1655156-c-8510.htm
and ill plug the other hole with a counter mounted soap dispenser,
but with that cheap of a faucet, ive decided to pull the trigger on an on-demand pump. i saw someone mention shurflo pumps on here somewhere, are there any other brands? any recommendations on which one i need, i noticed their smallest one said it wasnt for faucets (not sure what it is for). again im trying to stay as cheap as functionally possible.
Lunchbox7985
Postby GuitarPhotog » Wed May 29, 2013 8:46 pm
I've been using this one in my homebrewery for the last 20 years without trouble.
http://www.grainger.com/Grainger/DAYTON ... Pid=search
Designed for pumping drinking water on boats and RVs.
Not self priming but in a trailer it's pretty easy to keep the pump below the supply tank.
<Chas>
GuitarPhotog
Images: 55
Postby Lunchbox7985 » Wed May 29, 2013 9:01 pm
i should add, i could end up with the tank above the pump, but life may be easier if it didnt have to be. and of course with that faucet, i will want an on-demand pump, that starts up when i turn the faucet on, and stops when i let go.
Lunchbox7985
Postby Lunchbox7985 » Sat Jun 01, 2013 2:39 pm
what about this one, any thoughts?
http://www.amazon.com/gp/product/B002XM5G70/ref=s9_psimh_gw_p263_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=069DHPNGWH41S3QSR1ZV&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
can run dry, self priming, on demand. seems like everything i would need, and the price is more than doable.
Lunchbox7985
Postby Bogo » Sun Jun 02, 2013 1:41 pm
Lunchbox7985 wrote:what about this one, any thoughts?
SHURflos are well built, and have a good reputation. Also rebuild kits are available.
I notice it doesn't have a pressure switch. When you switch it on, it will run until you switch it off. This could be controlled with a faucet that has a built in switch or a switch next to the faucet. You can get ones that have a built in pressure switch. They will turn on when the faucet is open, and turn off when you close it. External pressure switches are also available, but will take a bit of plumbing to tie them in. I also notice it is 3 gallons per minute. That is way more than you need for a small sink faucet. 1 to 2 GPM would be much better. If the pump is oversized for the faucet flow rate, then the pump may cycle. If that happens, an accumulator tank will help.
This is a 1.1 GPM Flowjet with an on demand pressure switch.
http://www.amazon.com/LF122202A-Automat ... sbs_auto_5
Flowjet is also a good company, but not quite as widely sold as SHURflo.
SHURflo's accumulator tank.
http://www.amazon.com/SHURflo-182-200-P ... sim_auto_2
You can make your own with a T, short section of pipe, and some fittings. The pipe needs to be at least a couple inches in diameter and about a couple feet long. Cap one end. Use reducer fittings to mate the other end up to the T. Mount it with the capped end up. The tee then goes inline with the hose from the pump to the faucet. The trapped air will compress when the pump pressurizes the water. This style will eventually get water logged if left in use for years, but you will be draining the water system at least yearly so it should get it's air supply refreshed. A tire valve could be put into the cap end to allow refilling the air, but it isn't needed for RV use.
Bogo
Images: 39
Postby Lunchbox7985 » Sun Jun 02, 2013 3:15 pm
even better, and its cheaper. thanks!
what are the major benefits and drawbacks of a tank, i mean i get the point and all, but is it going to be all "spurt-y" without one? i could always add it later if its useable but slightly annoying without it.
Lunchbox7985
Postby alex k » Tue Oct 29, 2013 6:58 pm
113968
this is my sink with a pressurised water tank for doing dishes
and hand washing .
fill with some boiling water and it's a shower
total cost under $25.00
not to be confused with alexk from california
Green Lantern Corpsman
Coleman Keepers 200A Gang
alex k
Images: 34
