Where is your propane at?
Postby Visionsbydarrah » Fri Mar 01, 2013 3:20 pm
I know this is posted some where before, but here go's anyhow.
Where is your propane tank(s) mounted, inside or out and what size?
Just wondering because I personally use the 1lbs. bottles.
Pat
2011 Toyota FJ Cruiser.
2015 LittleGuy MyPod.
My YouTube Channel: https://m.youtube.com/user/TheVisionsbydarrah
Visionsbydarrah
Re: Where is your propane at?
Postby Verna » Fri Mar 01, 2013 4:03 pm
I have an 11 lb tank strapped to the front platform and tongue box with 3 ratchet straps. In the next couple of weeks I need to take battery tie-downs and fashion a better attachment, plus figure out a locking system.
Verna
Indianapolis, IN
Verna
Images: 49
Postby wingnut » Fri Mar 01, 2013 4:13 pm
A 25 lb. bottle on the tongue platform, that has a secure bottle holder, secured with a paddel lock.
wingnut
Images: 46
Postby Shadow Catcher » Fri Mar 01, 2013 7:58 pm
25# translucent tank on the tongue. I love the tank as you know exactly how much propane you actually have.
100408
Postby Visionsbydarrah » Fri Mar 01, 2013 9:21 pm
Shadow Catcher, what a cool looking tank.
I've never seen one like that before.
Pat
Visionsbydarrah
Postby vaddisonme » Fri Mar 01, 2013 10:04 pm
We have a aluminum trailer tongue box, with a central hole underneath for ventilation. It holds two of the 1-gallon (4.25 lb) propane tanks, held in place with a floaty noodle, and our front wheel cup.
The Marshmallow pulling our Sweet Potato.
vaddisonme
Postby Shadow Catcher » Sat Mar 02, 2013 8:34 am
Neither have any of the folks filling it :D
A 20# propane tank hold 4.7 gallons of propane a 25# holds 7.57 gallons and the Lite Cylinders are 30% lighter than a steel cylinder http://www.litecylinder.com . I have to give credit to one of the other members who bought his first.
Postby TPMcGinty » Sat Mar 02, 2013 9:59 am
To keep it simple I use the 1# disposable cylinders. I didn't want to run gas lines in my Tear. I know it is more expensive and not eco friendly but I like to do my cooking on the picnic table at the campgrounds anyways.
Tim
TPMcGinty
Images: 146
Postby nevadatear » Sat Mar 02, 2013 5:20 pm
11# bottle stored in the tongue box. Remove it a nd hook up at campsite. No propane line but the advantages of a bigger tank. Also use it for a firepit.
nevadatear
Images: 171
Postby Visionsbydarrah » Fri Mar 08, 2013 9:56 am
Ok, thanks for all the input. :D .
Pat
Visionsbydarrah
Postby Vindi_andy » Fri Mar 15, 2013 4:05 am
When it gets built I will have a 6 KG (13lb ish) on the tongue in a tongue box. Using the special lightweight cylinder which means full it weighs about the same as a 4.5 Kg (9lb ish)
Boys never grow in to men the toys just get more expensive and more dangerous
How true :)
Vindi_andy
Images: 49
Postby Glenlivet » Fri Jun 14, 2013 7:40 pm
On the tongue along with the battery and spare tire. It's held in place by the stand collar, a fixed pin in the back and a removable bolt in front. It sits just a bit loose so I can lift it a bit and see how heavy it is, how close to depleted.
Glenlivet
Postby GuitarPhotog » Sat Jun 22, 2013 3:56 pm
I carry my 20# propane tank on the tray on the tongue of my trailer. The tray is more flexible than a tongue box and weighs less, but requires strapping stuff down. But it requires no ventilation or weatherproofing.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Visionsbydarrah » Sat Jun 22, 2013 4:21 pm
All have been great ideas! And reasons why you put it there. :thumbsup:
Pat
Visionsbydarrah
Postby Mdrinnon » Wed Jul 24, 2013 10:37 am
I am just entering the planning stage of a Gypsy Vardo style. I'd love to put mine in wooden hand built/decorated boxes to either side of the door in the rear. However I can only imagine the effects of a rear end impact from another driver :shock: lmao
Mdrinnon
Images: 37
