Semi standy with opening roof
Postby Johnysteam » Mon Sep 16, 2013 8:37 pm
Started dec 2012 :D
Johnysteam
Images: 40
Re: Semi standy with hinged convertable roof.
Postby KCStudly » Mon Sep 16, 2013 8:42 pm
Welcome to the forum.
Build on. :thumbsup:
So what's the plan?
Images: 8117
Postby Johnysteam » Mon Sep 16, 2013 8:53 pm
Floor stage
Johnysteam
Images: 40
Postby Johnysteam » Tue Sep 17, 2013 6:37 am
I then spent months contemplating what to do. I did a few mock constructions with temporary materials.
We decided we needed,
*3 beds going widthways
*5 foot 4 inches head room for the misses, and 5 foot 9 inches for me ( it sounds strange but read on)
*A decent amount of indoor bench space for an indoor kitchen, but provision for a rear kitchen outside.
*Teardrop or similar design
*For it to be able to be stored in our garage with a 6 foot 3 inch high opening restriction.
*Be able to use the old pop up awning, which must be a replacement because its in good order.
112399
Trial run with helper
Johnysteam
Images: 40
Postby jmarlowe » Tue Sep 17, 2013 8:40 am
Welcome,
It appears we are in a similar position, with some shared goals (except I would require a bit more headroom). I was given a frame from a pop up and am coming up with a plan. I'm curious to see some mock ups or drawings of what you have planned. Why the inside/outside kitchen?
Enjoy!
jmarlowe
Postby Johnysteam » Thu Sep 19, 2013 3:44 am
jmarlowe wrote:Welcome,
Enjoy!
Hi, This has only an indoor kitchen. both types of kitchens have their advantages. Conditions are not always ideal for outdoor cooking, and we get allota wind.
But cooking inside a little camper is a worry, too.
Johnysteam
Images: 40
Postby Johnysteam » Thu Sep 19, 2013 3:56 am
This was taken 3 months ago. It was easy to do the basic construction, but I found the finer finishing work has really slowed me down :NC
I have framed out a very tall doorway, to minimise bending down while going thru the door.
The layout comprises of, beds running across , single at front, double at rear. double has dining table underneath.
Ply construction. 5/8 inch treated pine ply floor, 1/4inch pine ply inside walls, 3/24inch hardwood marine ply exterior cladding, 3/24 ply roof
112450
112451
Johnysteam
Images: 40
Postby cjkrause » Thu Sep 19, 2013 4:15 am
Welcome aboard
great ideas and looks like it is going to be awesome when all done :thumbsup:
Son's Memorial Webpage- http://www.mem.com/ContentDisplay.aspx?ID=9309868
CJs Performance- Trifecta Tuning Dealer since July 2006. Oldest and most active dealer for Vince to this day
Click here for- http://cjsperformance.com/]CJs Performance and Original Texas Headskins
cjkrause
Postby Johnysteam » Thu Sep 19, 2013 4:20 am
Yesterdays photo, The roof tilts to go from 5foot 4 to 5 foot 11 inches.
It is hinged at the back, and will have gas struts.
A fair amount of trial was done before the back hinging decision, as the rear of the camper is way lower than the front, and space above the door was critical.
Now I can walk straight in to the camper with a straight back!!
My current dilemma is do I use canvas for the infill when the roof is raised?? or sandwiched ply/ timber core?? :thinking:
112449
Johnysteam
Images: 40
Postby Johnysteam » Fri Sep 20, 2013 5:21 am
112475
plywood cabinet. sink to go in, and stove later...when dollars allow
Johnysteam
Images: 40
Postby bc toys » Fri Sep 20, 2013 8:01 am
Looking great :thumbsup: :thumbsup:
bc toys
Images: 42
Postby KCStudly » Fri Sep 20, 2013 9:54 am
Looking forward to a roll out so that we can see the top in the raised position.
+1, looking great! :thumbsup:
Images: 8117
Postby aggie79 » Fri Sep 20, 2013 1:26 pm
KCStudly wrote:Looking forward to a roll out so that we can see the top in the raised position.
Me too! :applause:
For more on our Silver Beatle teardrop:
Images: 676
Postby Johnysteam » Sat Sep 21, 2013 12:23 am
112505112504
Exposed roof spars will remain at this stage, maybe lined later with styrene and carpet.
fridge cabinet shown here.
The only major mistake I've made recently is thinking I would have time to make the window frames and sashes from wood, so I cut out openings to suit this.
Only to realise later that I needed to buy readymade used ali windows which were not the ideal size........ :frightened:
The black tar coating on the chassis has kept it rust free
Johnysteam
Images: 40
Postby Johnysteam » Sat Sep 21, 2013 12:25 am
112503112502
Got to get all that mains prewiring professionally completed by an electrician.
Johnysteam
Images: 40
