Propane Not Working - The Mystery Begins
Postby DudKC » Thu Oct 10, 2013 5:21 pm
Now that we're pretty much done with most of the heavy lifting on the build I figured I would get the propane bottle filled up and test out the sweet stove I saved from the original '72 Starcraft. When I hooked it all up, much to my dismay, no propane came out. I have some pics below if that helps. When I tighten the regulator all the way and turn on the tank, I hear no sound and smell no propane. Then when I walk back to the stove and turn on all 3 burners, I also hear no sound nor smell any propane. The next step is to turn off the burners and walk back to the front of the camper. Then I slowly unscrew the regulator, with the tank on, and as the regulator gets about a quarter to half way unscrewed I hear a whoosh of propane and smell a little bit of propane, but that's it - very fleeting and it stops suddenly.
For the next test I unhooked the flex line from the stove, so now the propane bottle is hooked up to the regulator, which is hooked up to the 1 inch black pipe running under the camper, and no stove attached. Now, when I turn on the propane in these circumstances I also hear nothing and don't smell any propane (at the bottle and back at the open black pipe).
I believe we might have a faulty regulator, but if anyone has any suggestions or wisdom to offer I would be all ears.
Thanks!
Burner hookups - hopefully there isn't a valve or something that I'm missing
Dustin
View my build thread here:
http://www.tnttt.com/viewtopic.php?f=50&t=42426
DudKC
Images: 100
Re: Propane Not Working - The Mystery Begins
Postby Shadow Catcher » Thu Oct 10, 2013 5:34 pm
One thing you need to do is open the valve on the propane tank very slowly, The problem may be caused by flow restrictors built into the 20# propane tanks so that when Fido chews through the black chew toy there is not a huge gush of propane, and that discontecting, then reconnecting the screw-on regulator fitting to the tank and slowly opening the valve should soleve the problem.
Postby DudKC » Thu Oct 10, 2013 6:17 pm
Ok, I just disconnected the regulator, then reconnected it. So tight that it squeaked and I couldn't tighten it any more. Then I put my ear right next to the bottle and slowly opened the valve. I heard a very faint woosh of propane, that lasted about a half second or less, then nothing. No propane coming out of the open black pipe at the back either.
One thing I did notice when I took off the regulator - There is a black "O-ring" on the part that fits into the bottle, and it has a slight gash in it. It still has it's circular shape, but there is a noticeable gash in it. I wonder if that is not allowing a good seal...
Dustin
DudKC
Images: 100
Postby DudKC » Thu Oct 10, 2013 6:20 pm
I'm also assuming that eventually I'll need to clean off the dried pipe dope from where I disconnected the flex line from the black pipe (see 2nd pic in OP), and reapply new pipe dope when I reconnect it.
Any suggestions on what to use to do that? Or do I just slap new pipe dope over it and reconnect it?
Dustin
DudKC
Images: 100
Postby len19070 » Fri Oct 11, 2013 7:12 am
Remove your regulator. If there is anything resembling oil on or at the fittings (or anywhere for that matter) Your regulator is bad.
Happy Trails
Len
len19070
Images: 24
Postby Dale M. » Fri Oct 11, 2013 10:17 am
One issue I have found is regulator snout does NOT extends into tank valve far enough (even when fully tightened) to fully open anti flow/anti surge valve.... Try different tank or different regulator attachment fitting.....
IF they are good, then you regulator is bad....
Its pretty simple, either tank valve or regulator is problem...
Dale
Dale M.
Images: 18
Postby Larry C » Fri Oct 11, 2013 10:24 am
DudKC wrote:I'm also assuming that eventually I'll need to clean off the dried pipe dope from where I disconnected the flex line from the black pipe (see 2nd pic in OP), and reapply new pipe dope when I reconnect it.
You don't put ANY dope on the those threads. That is a parallel thread and a flare connection. The seal comes from the flare seat, not the threads as it does with the NPT threads.
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby Larry C » Fri Oct 11, 2013 10:28 am
Another thought: Did you install the fitting into the regulator? If so, is there a directional flow shown on the regulator e.g. in/out or an arrow? Maybe the regulator is connected backwards??
Larry C
Images: 78
Postby DudKC » Fri Oct 11, 2013 10:52 am
Noted. Should I clean it off? Or just reconnect it?
Dustin
DudKC
Images: 100
Postby DudKC » Fri Oct 11, 2013 10:53 am
Larry C wrote:Another thought: Did you install the fitting into the regulator? If so, is there a directional flow shown on the regulator e.g. in/out or an arrow? Maybe the regulator is connected backwards??
I did not install the fitting into the regulator. It came in a package already assembled as you see it in the first pic in the OP.
Dustin
DudKC
Images: 100
Postby DudKC » Fri Oct 11, 2013 10:55 am
Dale M. wrote:One issue I have found is regulator snout does NOT extends into tank valve far enough (even when fully tightened) to fully open anti flow/anti surge valve.... Try different tank or different regulator attachment fitting.....
Dale
Well, both are new so that is disappointing. I had the propane bottle filled for the first time on Wednesday and when they filled it they didn't have any trouble at all, so my guess is the regulator is bad. I will get a new regulator hooked up sometime this weekend and give that a shot.
Thanks for all the replies, I'll still listen to any suggestions.
Dustin
DudKC
Images: 100
Postby Larry C » Fri Oct 11, 2013 11:10 am
Dale
Was it a brand new never filled tank? Did they purge the tank by putting a small amount of propane in it and venting it to atmosphere? They need to do this several times to get the air removed from the tank. Maybe that's your problem?
Larry C
Images: 78
Postby Larry C » Fri Oct 11, 2013 11:12 am
Yes clean it off, and don't damage (scratch) the flare seats (male and female)
Larry C
Images: 78
Postby Dale M. » Fri Oct 11, 2013 6:38 pm
Verify its correct, IN from tank, OUT to stove..... Just because its factory assembled does not mean its right.... Person assembling it probably did no understand English.....
Dale
Dale M.
Images: 18
Postby DudKC » Fri Oct 11, 2013 6:43 pm
Dale
It is correct in that facet. Even though it was made in Mexico.
Dustin
DudKC
Images: 100
