Finish Coatings
The function of a finish coating like paint or varnish over an epoxy barrier coat, is to decorate the surface and protect the epoxy from sunlight. In doing so, the finish coating extends the life of the epoxy moisture barrier, which, in turn provides a stable base that extends the life of the finish coating. Together the two form a protective system far more durable than either coating by itself.
Protection from sunlight is a primary consideration in the selection of a finish coating. Long term UV (ultraviolet) protection of the barrier coat depends on how well the finish coating itself resists UV and keeps its pigments, or its shield of UV filters on the surface of the epoxy barrier coat. A high gloss finish reflects a higher proportion of the light hitting the surface than a dull surface. All other thing being equal, a white (especially a glossy white) coating will last the longest.
Most types of coatings are compatible with epoxy. Thoroughly cured epoxy is an almost completely inert hard plastic. This means most paint solvents will not soften, swell or react with it. However, it is still a good idea to build a test panel to assure coating compatibility.
Tom Kurth wrote:Be aware, even with inhibitors, even with some kind of varnish or poly overcoat, epoxy WILL, not may, suffer UV degradation. Paint is a more sure overcoat. If you want a clear coat use a top quality marine (not spar) varnish or an automotive clearcoat. Honestly, I don't know about the automotive for sure. Even with a good marine varnish, it will need to be renewed frequently (understand that as annually.)
Best,
kd5edj63 wrote:I wonder if I should have asked, Is it necessary to epoxy UNDER paint that is my question
kd5edj63 wrote:I am back to contemplating using epoxy primer instead of the clear epoxy. Anyone think thats a bad idea
kd5edj63 wrote:The only thing that is different is that in the past I primarily used polyester resin, but I think I can adapt to using large amounts of epoxy.
