Stuff you don't need
Postby Socal Tom » Thu Jan 02, 2014 9:20 am
I've recently remodeled my galley, and I've set a goal to reduce or eliminate the stuff I have to carry in my bed area. I thought it might be fun to start a topic of the stuff you stopped brining on every trip ( or maybe stuff you should stop bringing).
For me, now that I have a 1gallon bulk propane tank I don't need 4 one lb bottles. ( I'll still bring one just in case)
I don't need the air conditioner for every trip ( see hacking a frigidaire in my future )
I probably don't need the 4 quart pot, but it's still in there.
I'm questioning whether I really need the Coleman propane lantern.
How about you?
Socal Tom
Images: 9
Re: Stuff you don't need
Postby bobhenry » Thu Jan 02, 2014 2:09 pm
Never never a microwave.... Took one to one gathering never again.
I have serious doubts about the toaster oven now that I do the biscuits in the dutch oven. So it will probably be left behind as well this season.
However I will still bring my red neck hot water heater as long as it is an AC equiped campsite. Its great to have hot water for beverages as well as dish cleanup.
9000 Club
9000 Club
Images: 2318
Postby Shadow Catcher » Thu Jan 02, 2014 7:57 pm
What we take is tailored to the trip and conditions, the hacked Frigidaire is taken when we expect hot weather and will have 120V AC. This is basically the rule with many of the items in the, what to take or leave behind.
With AC
the electric fry pan
small electric coffee maker
electric ceramic heater (when you don't need the above)
Left home the inverter
with out AC
French Press coffee maker
nonstick fry pan
take the inverter
Espar diesel heater (uses the same hose and ports as the Frigidaire)
Now we can use the water heater heater. Make sure the propane tank is full.
Last edited by Shadow Catcher on Fri May 06, 2016 8:03 am, edited 1 time in total.
Images: 193
Postby slowcowboy » Fri Jan 10, 2014 7:30 am
wood for campfire. for me. probaly don't need a coleman stove or really don't need a coffee pot ether!
lots of pots and pans. unnessary.
soap for washing dishes in camp.
they get washed at home!
two boat motors gas or electric. lot bettor just to pull the battery out of the teardrop and run the electric on the jon boat.
milloons of fishing poles.
one fishing pole for one type of fishing will work fine.
more than one lantern! don't bring the hole coleman collection!!!!!!!!!!!!!!!!!!!!!!!!!!
12 volt works fine for lights.
slow
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Postby Wolffarmer » Wed Feb 05, 2014 4:03 am
No propane lanterns. No telephones turned on. No tv.
Randy
Wolffarmer
Images: 305
Postby Jst83 » Thu Apr 03, 2014 6:29 pm
I've been learning from my Boyscout brother ( his son got Eagle last year ), did away with cups and plate more to wash we use paper now and just burn it easy clean up. Mix eggs in a gallon ziploc no bowls to clean again fire does my clean up.
Been slowly doing away with stuff myself so when I get there set up is faster and teardown is quick.
Jst83
Images: 215
Postby Weirdnerd » Fri Apr 11, 2014 10:40 pm
I am planning to replace my plastic plates and cups for white porcelanized steel dishware, old school and they last for decades. the rest stays as it is. I have the bare minimums, a fantastic fan, a Coleman pro cat heater, that little heater has kept me warm and safe in deep Colorado winter, solar panel, 20 lb propane bottle that lets me cook for 45 days straight , two 6 gallon water jugs, LED lights....I can't think of anything else I would need.
This is my build thread...
Weirdnerd's teardrop
Weirdnerd
Postby Shadow Catcher » Sat Apr 12, 2014 7:28 am
Back in the day when we were tent camping with a growing family we picked up a Coleman Peak set that includes five SS plates pots and pans that all nest into one large pot. This is I think was aimed at outfitters.
Images: 193
Postby Wolffarmer » Sat Apr 12, 2014 7:41 am
I stop in at thrift stores and pick up some Correll plates and bowls. Cheap and I like them a lot better than the porcelain ware or other all metal ones. And I also pick up camping flat wear while there. Using paper and plastic just rubs me the wrong way and washing a plate and flat wear with the pots and pans is not all that hard. And I usually have enough that the last day or two I don't wash anyway just wait till I get home.
Randy
Wolffarmer
Images: 305
Postby bdosborn » Sat Apr 12, 2014 9:28 am
Weirdnerd wrote:I am planning to replace my plastic plates and cups for white porcelanized steel dishware, old school and they last for decades. the rest stays as it is.
You might try one before you replace all your plates. We found that the porcelain steel tends to draw all the heat off the food and it gets cold quick. We went back to the plastic for that reason.
Images: 451
Postby Weirdnerd » Sat Apr 12, 2014 11:03 pm
I may have to try that... I don't like plastic because it gets scratched easily when you cut stuff on the plates, and glassware breaks too...gack...tough choices coming my way...
Weirdnerd
Postby Socal Tom » Mon Apr 14, 2014 4:20 pm
I recently found a set I've been coveting. Its made of bamboo, natural, dishwasher safe, insultates the heat, and should last a good while.
They are on my list so I can cut out the paper plates and stuff.
http://www.amazon.com/Texsport-Person-P ... B007FCTNH2
Socal Tom
Images: 9
Postby dmckruit » Wed May 07, 2014 8:27 pm
I use the enamelware metal plates but put a paper plate on top. The metal plates make the food cold faster and the paper plates (the thin ones) fold in your lap. Combined they work great. I use insulated travel mugs with lids for hot beverages such as coffee, and these also work well if they are not see through to hide your beer from the park rangers. :D
dmckruit
Images: 212
Postby citylights » Wed May 07, 2014 8:50 pm
I am going the other way! Started with a pretty empty tear this year. (Just finished building it) Added gear to store and use in it...
2 LED flashlights and LED lantern
First aid kit
Two folding chairs
Folding picnic table
20lb propane and cook top
Serving set of 4 enameled ware, plate, bowl, cup, fork, knife, spoon
Carving knife, BBQ fork, stainless spatula, stainless serving spoon
Stainless peculator coffee pot
Cast iron fry pan and Dutch oven
Teardrop bed linens, pillows
Wind proof matches, paper towels, trash bags
citylights
Postby citylights » Wed May 07, 2014 9:24 pm
Socal Tom wrote:I recently found a set I've been coveting. Its made of bamboo, natural, dishwasher safe, insultates the heat, and should last a good while.
Wow, I like the look of those!
citylights
Return to Camping Secrets
